computer help needed
computer help needed by Rich on Fri Sep 05, 2008 5:16 pm
hi all you can anyone tell me how i can access my pc off my laptop they both run vista i want to be able to get in to my saved files and favorites and transfer them to the laptop
Re: computer help needed by nigelbread on Fri Sep 05, 2008 7:24 pm
Hi I use one of these at my 10 year olds insistance
4GB SAMSUNG USB MEMORY FLASH STICK
ebay Item number: 220276419333 others available!!
suprising how efficent they are. I gave up trying to link two computers due to cost.
nigelbread
Modifications: +
Re: computer help needed by bobbinsjob on Fri Sep 05, 2008 8:06 pm
you need a wireless router with both units connected to it and the files and folders must be set to "shared".
NORTON does tend to f&$k things up though
Re: computer help needed by jellybaby on Fri Sep 05, 2008 10:17 pm
i run one computer with XP and one with vista can i still share wirelessly ????????????
Re: computer help needed by ukcobra on Sat Sep 06, 2008 8:43 am
Using a Router you can share files from any computer on the network.
You should have no problems sharing fines between Vista, XP and a MAC on the same network.
Ensure the files are in the shared folder, that the computers are switched on and on the same Workgroup/network. The Networking wizard setup in Vista and XP is probably the easiest way to go through the setup.
Alternatively, you can use something like a Network Attached Disk, which means you can store files on a box that sits on the network, meaning you do not need the other PCs on to access the shared files.
I use a DLINK DNS-343 to do this.
Mark
ukcobra
Modifications: 96 2.0 S SWB
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
Re: computer help needed by Rich on Sat Sep 06, 2008 11:11 pm
cheers guys got it sorted no
