oil change
oil change by fred on Wed Sep 03, 2008 11:47 pm
how many things need the oil changed?
its a swb a 2.0l sport.
ive changed the engine oil and the rear diff oil.
now is there just the Gearbox /Transfer Box to do? and is this the one thats all in one that i can fill via the hole the little gear lever leaves when removed? and uses engine oil ?
thanks inadvance for any info.
fred
Registration Year: 1994/M
Modifications: swb...
16" pajero alloys with insa turbo special tracks on.
rear window tints.
suspension & 3" body lift.
snorkel.
bullbar extended.
petrol tank lifted higher.
30mm wheel spacers.
3 point harnesses
Re: oil change by woodwizzard on Thu Sep 04, 2008 7:57 am
There is also the front diff to do with gear oil. The gearbox and transfer have seperate drain and fill holes so am not sure if both will be filled through the gearbox. You can fill the gearbox that way and I'm sure someone will advise about the transfer, and yes, use engine oil.
Re: oil change by Drift on Thu Sep 04, 2008 8:33 am
There should be a drain and filler plug, the problem with filling through the gear stick is its to easy to over fill.
Re: oil change by Rifleman on Thu Sep 04, 2008 9:10 am
Refill plug is directly below the gearstick. If filling through the gearstick hole, remove the plug to allow any eccess to overflow. Use engine oil, but only 10/30 - 10/40.
Remember to check BOTH axles, and while you are under there you would be as well to grease the propshaft nipples.
Re: oil change by Road Hog on Thu Sep 04, 2008 9:38 am
Remember to always undo the filler/level plug before the drain plug.
