Frontera Technical Support • View topic - renault scenic coil packs ???
renault scenic coil packs ??? by my 2.5 tds on Thu Aug 28, 2008 10:32 pm
evening all :wink:
( not sure if this is in the right place :oops: )
im trying to get my brothers renault scenic ready for him getting back from afganistan next month
but common fault with these is COIL PACKS it has 4 seperate coil packs 1 on top of each plug
there seems to be atleast 1 not working :? roughly £ 25 each from motor factors :(
does anyone know of an easy way to test these with out having to hook it up to a machine ???
or is it just a case of taking 1 off with the spark plug and putting the end off the plug up against something metal and if theres a spark its ok ???
any help would be much appreciated :wink:
.....Paul.....(97 ) ( p - reg ) 2.5 tds lwb
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by wisecobandit on Thu Aug 28, 2008 10:39 pm
You should be able to test them with a multimeter for ohms etc but you would need a haynes manual for some reference for what figures they actually should be.
Has a coilpack gone down totally?
Tried unplugging 1 coilpack at a time with the engine running and comparing each cylinder note at a time?
If its just 1 cylinder and the same coilpack is used just buy 1 and interchange it down the line until you find the duff one.
wisecobandit
Modifications: 265/75/16 insa turbo's
2" Bodylift now ordered
Snorkels next on the list!
Re: renault scenic coil packs ??? by my 2.5 tds on Thu Aug 28, 2008 10:48 pm
have a look folks
clickme
my 2.5 tds
Re: Renault scenic coil packs ??? by garyw on Thu Aug 28, 2008 10:51 pm
had this problem with wifes scenic went down the same route as you are only to be told by Renault that this shorts out coil pack? & that they give up in pairs? the way that they test them is to disconnect one at a time if it runs the same not that one :roll: if worse thats the one that buggered :roll: ( very technical these Renault mechanics thousands of pounds gadgets & still dont know how to use them :D :D ) £25 each is cheap renault wanted £80 each fitted.
hope this is of some help
gary
garyw
Re: Renault scenic coil packs ??? by my 2.5 tds on Thu Aug 28, 2008 10:58 pm
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by garyw on Thu Aug 28, 2008 11:19 pm
yer i got it the wrong way round, :drink: to many to night
gary
garyw
Re: renault scenic coil packs ??? by my 2.5 tds on Thu Aug 28, 2008 11:30 pm
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by Alfie on Fri Aug 29, 2008 6:54 pm
Had this trouble with my Laguna, RAC man replaced what he told me was the duff one to find the following day we'd had two go together. Price sounds good I paid £40 each.If two are faulty its still possible to tell by removing them one at a time.Then swap the possible dud for one you know changes the engine note when its removed. :D
Vehicle Name: Dino
Re: renault scenic coil packs ??? by my 2.5 tds on Fri Aug 29, 2008 9:52 pm
update
evening all :wink:
well got me confused this :?
with engine running
unpluged coil pack 1 and engine cut out ( so guess this 1 is ok )
unpluged coil pack 2 and the engine note droped but didnt cut out :?
unpluged coil pack 3 and the engine note droped but didnt cut out :?
unpluged coil pack 4 and engine cut out ( so guess this 1 is ok )
what i cant understand is with the engine note droping on 2 & 3 when unpluging them ( does this mean there ok :?: )
thanks again :wink:
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by Alfie on Sat Aug 30, 2008 9:42 am
Same as my Laguna, change 1and 2 over, see if 2 dies and 1 changes the engine note, change 3 and 4 and check for the same. It seems you have two duff ones. They are well known for failing in pairs. Sounds like 1and 4 are ok.
Vehicle Name: Dino
Re: renault scenic coil packs ??? by john (smifffy) on Sat Aug 30, 2008 9:48 am
if you put what model and engine it has i will see if i can find the ones you want avalible from auto factors
Re: renault scenic coil packs ??? by my 2.5 tds on Sat Aug 30, 2008 10:47 am
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by my 2.5 tds on Sat Aug 30, 2008 10:51 am
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by my 2.5 tds on Sat Aug 30, 2008 1:18 pm
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by garyw on Sat Aug 30, 2008 2:07 pm
garyw
Re: renault scenic coil packs ??? by my 2.5 tds on Sat Aug 30, 2008 2:22 pm
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by my 2.5 tds on Mon Sep 01, 2008 12:19 pm
update
:D 2 new coilpacks and problem sorted :D
:wink: thanks guys for all your help :wink:
have a look folks
clickme
my 2.5 tds
Re: renault scenic coil packs ??? by Alfie on Sun Sep 07, 2008 3:09 pm
Just back of my holidays, nice to see you've got it sorted :D
Vehicle Name: Dino
Re: renault scenic coil packs ??? by my 2.5 tds on Sun Sep 07, 2008 3:30 pm
have a look folks
clickme
my 2.5 tds
