sump plug ,
sump plug , by kingfisher on Thu Aug 28, 2008 8:39 pm
hi all , i have now got my engine ready to go back in , but i have hit on a small problem , when i tightened up the sump plug it just wouldn,t tighten , so i tried it with the washer off and it tightened up ,so what i have done ios buy another plug but a 14mm ford plug , they are a bit longer , and it tightened up a treat , what i want to know is would there be enough clearence in the sump ,, its a c20ne engine , any ideas :?:
kingfisher
Vehicle Name: The money pit
Re: sump plug , by alex on Thu Aug 28, 2008 8:58 pm
How much longer? its a safe bet looking at the sump, how deep it is and from that how deep the inards are. As long as its smaller you should be ok.
From memmory, I am surprised that the sump is M14, though it was bigger.
Re: sump plug , by Road Hog on Thu Aug 28, 2008 9:15 pm
Assuming the sump is fitted to the engine,put a socket on the crankshaft nut & turn it over a couple of times by hand.
That way you will feel/hear if anything touches.
Re: sump plug , by Trugga on Thu Aug 28, 2008 9:17 pm
This is what came in the spares package to my 2.0 Sport:
Part number (on the bag) 1#94310917 7-02-215 GR.4.105
M20x12 with a 24mm A/F hex head
Curiously, EPC lists the "plug, oil drain" as 90409376 6-52-475
I do not know if my spare is the correct size.
Re: sump plug , by FUDDY MUCKER on Thu Aug 28, 2008 9:22 pm
That looks about right Lawrence.
I brought a new one a few weeks back, cost me a whole £2.25 :shock: :shock: :shock:
Re: sump plug , by Road Hog on Thu Aug 28, 2008 9:25 pm
"Engine Oil Fill" looks like the filler forthe gearbox :?
All the B`s & the 2.8 tdi are known to be M 14 :wink:
Re: sump plug , by Trugga on Thu Aug 28, 2008 9:32 pm
I bow to the A friend's knowledge on this one... indeed, EPC advises that the plug in my picture above is for the "rear transfer casing" for the C20NE, X20SE, C24NE, 2.3TD, X22XE and 2.5TD variants.
Sorry for any confusion.
Re: sump plug , by kingfisher on Sun Aug 31, 2008 12:11 am
thanks guys , i have turned it over by hand and there was no noise or resistance ,tommorrow (sunday ) is d day , going to put he rad on fill up of oil , and turn the key , so fingers crossed , :wink:
kingfisher
Re: sump plug , by Drift on Sun Aug 31, 2008 12:16 am
See here for how I .. sorry A friend resolved my sump plug saga :wink:
viewtopic.php?f=21&t=16954
Re: sump plug , by kingfisher on Sun Aug 31, 2008 11:59 pm
well i put the rad on ,filled it of oil , turned the key ,nothing , had a look ,everything seemed ok , tried again nothing , at that moment , the mrs came out with a cuppa , asked how i was getting on i said ok just waiting for the oil pump to pump some oil around the engine before i started it up . :oops: then she said whats this plug thing go to ,(the one on the coil ) thats to the steering pump , thats goes on last :oops: , so when she went in i connected the plug and yes it fired up like a goodun , went in told the mrs see told you i could do it , :oops: :oops: :oops:
kingfisher
Re: sump plug , by Drift on Mon Sep 01, 2008 12:01 am
:lol: :lol: :lol: :lol:
