Frontera Technical Support • View topic - PC boys-Where art thou?
PC boys-Where art thou? by brachunky on Sat Aug 16, 2008 4:49 pm
Guys Im more frustrated with pc's than removing ball joints from a fronty :evil: :wink:
Who knows whats up here:
Im finally building a pc from oldish parts to run Linux on but have not even got to see the bios setup screen yet as there are no graphics at all.I have tried alternative monitors and graphic cards but still no activity on the screen.When I switch the pc on,the fans(including the graphics card fan) & harddrive start up but no connection to the monitor.(Monitors led remains orange when it should be green when properly connected). Would clearing the cmos maybe help?
The main kit im using is:
Gigabyte GA81848PM motherboard
Gainward G4TI4200 128MB graphics card
512mb ddr memory
P4 3GHZ HT Prescott chip
Thanks guys :oops:
3 inch suspension lift
31 10.5 Muds
Re: PC boys-Where art thou? by nitromotor on Sat Aug 16, 2008 4:55 pm
Check the graphics card is in the (correct) slot on the mobo securely
Also check other cables are in the correct place, check if the ram is seated properly too
Re: PC boys-Where art thou? by brachunky on Sat Aug 16, 2008 5:02 pm
31 10.5 Muds
Re: PC boys-Where art thou? by nitromotor on Sat Aug 16, 2008 5:07 pm
have a look at the pins in the (monitor)plug,for damaged /missing pins
If it is a bios prob, remove the battery then find the reset pins if it has them (close to battery)and short together momentary
then reboot, this may load the default bios options
Re: PC boys-Where art thou? by Sir-Doris on Sat Aug 16, 2008 5:21 pm
Check to make sure the CPU and heatsink are seated correctly and have a thin smear of thermal paste or a thermal pad between them. This can cause the problem you are having. If the CPU and Board are relatively old the paste/pad can 'dry up' so to speak.
Re: PC boys-Where art thou? by Trugga on Sat Aug 16, 2008 5:39 pm
When powering on, is there a beep ? If not, then possibly something is connected incorrectly.
Disconnect the hard disks and other ancillaries and try powering up.
Once you get the beep (or beeps), you can start adding drives and cards ntil you find the offending part.
Re: PC boys-Where art thou? by alex on Sat Aug 16, 2008 6:00 pm
Yeah, as Lawrence said is it making all the noises? single beep at post and all the hdd jittering like it wants to boot. If so its vid card.
reset bios, take it the gf4 is agp, the mobo may be booting off a pci vid card. The vid card doesnt draw much juice, but what wattage is the psu?
Re: PC boys-Where art thou? by alex on Sat Aug 16, 2008 6:06 pm
Got the manual for the mobo here
http://uk.giga-byte.com/Support/Motherb ... uctID=1705
Its an 8x agp, I remember the gf4's were around 4x . there was some conflicting with older agp's and newer, something about the voltage difference and possible motherboard damage.
Whats the specific vid card? do you have any old pci vid cards to plug in for a mo?
Re: PC boys-Where art thou? by brachunky on Sat Aug 16, 2008 6:18 pm
Thanks chaps but still no luck :cry:
Checked pins on cables
Redone the thermal paste
Disconected all ancilleries and still no go but did note that there are no beeps at all
The vid card is definately a AGPX8
I have tried another monitor as well as plugging in the original video card which came with the mobo(radeon 9200se) and still nuttin. Also tried removing the cmos battery .I think the absence of beeps may hold a clue.
31 10.5 Muds
Re: PC boys-Where art thou? by alex on Sat Aug 16, 2008 6:21 pm
Is the spaeker fitted to the board? no beeps, mobo dead mate.
Re: PC boys-Where art thou? by brachunky on Sat Aug 16, 2008 6:23 pm
31 10.5 Muds
Re: PC boys-Where art thou? by alex on Sat Aug 16, 2008 6:30 pm
Shame mate, are all the fans turning?
Re: PC boys-Where art thou? by brachunky on Sat Aug 16, 2008 7:08 pm
yup!Not to worry :wink: I have pulled out an old celeron based pc to have a go on :lol: I will looking out for a used socket 778 mobo on fleabay as I think its probably that which is knackered :lol:
31 10.5 Muds
Re: PC boys-Where art thou? by weave67 on Sat Aug 16, 2008 9:26 pm
have you tried re configuring the twirly swizzler :roll:
Re: PC boys-Where art thou? by brachunky on Sat Aug 16, 2008 9:34 pm
31 10.5 Muds
Re: PC boys-Where art thou? by Sir-Doris on Sat Aug 16, 2008 9:39 pm
Another thing to check, is the power supply big enough for that cpu, should be at least 350 watts, preferably 400 watts for a Prescott cpu.
Also, on some motherboards there is a 2nd, 4 pin power socket that also needs to be attached. the pins will be arranged in a square. newer motherboards have this built into the main motherboard power connector as they may have 24 pins, older boards have 20 pins and sometimes the extra 4 are on a seperate block on the board, this is most common on intel based boards. Also some graphics cards need a feed from the power supply as well.
Here is a picture of the little blighter in the foreground with the 20 pin connector in the background to the right of the RAM chip.
Re: PC boys-Where art thou? by Alchamist on Sat Aug 16, 2008 11:14 pm
Has to be said that it sounds to me like a dead motherboard on there, as it's failing to POST. I would just see if you have another PC to test the graphics card in, but usually an AGP fault will force the motherboard to give an error beep on boot.
If you remove the memory from the slots, do you get any error beeps from the motherboard? If not, double check the speaker is ok, and if it is, then it is almost certainly the motherboard that is dead.
If you do get error beeps then the motherboard is probably ok. Try firing up the system without the hard drives connected, to make sure there isn't an IDE error (has been known to stop motherboards POSTing in the past).
Gigabyte motherboards can be a little flakey from time to time, and are not well known for giving useful diagnostic information when something isn't quite right.
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: PC boys-Where art thou? by brachunky on Sun Aug 17, 2008 10:33 am
Cheers Phil & Jay for those last suggestions,it would seem that the mobo has gone as there are no beeps at all and the g/card works fine on another pc I have going.
The power supply is a 400w unit, and as said is connected up proper with the additional 4 pin plug attached.
Its a pity really as the prescott HT chip would have been a nice base for a linux machine.On fleabay you can get plenty used 478 boards but the HT types seem to be far more expensive. Guess I carry on lookin :lol: :lol:
31 10.5 Muds
Re: PC boys-Where art thou? by brachunky on Sun Aug 17, 2008 8:31 pm
Well gents :D I am now using my linux(ubuntu) pc to write this and so far so good :wink: Spoke to a mate this afternoon who kindly donated me a P4 2.6ghz base unit :dance: Fitted a harddrive,memory,new cooler and THAT graphics card and away it zoomed! Well happy that Uncle Bill has nowt to do with this :lol: :lol:
31 10.5 Muds
Re: PC boys-Where art thou? by Sir-Doris on Mon Aug 18, 2008 2:20 am
I know you already have a pc up and running but it seems a shame to give up completely on the old one. Another thought, have you tried resetting the BIOS on the m/board?
