Frontera Technical Support • View topic - How can i tell?
How can i tell?
How can i tell? by FRN-71E on Fri Aug 15, 2008 8:47 am
I have a 1995 Holden Frontera Sports with 2.oL Opel motor and coil rear end, but want to know wat series it is? as i wouldnt have a clue how to tell as there really only ever brought out 3 different Sports out here in oz!
If any one can shead some light would be great! thanks
mitch!
FRN-71E
Modifications: * 3inch suspention lift
* 1inch body lift
* 30x15r16 all terrains
* Dinted panels
* manual locking hubs!
* SIG front locker
Re: How can i tell? by Red Oktober on Fri Aug 15, 2008 8:50 am
it's an A series
the B series started when the body shape changed
Re: How can i tell? by FRN-71E on Fri Aug 15, 2008 8:55 am
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: How can i tell? by Red Oktober on Fri Aug 15, 2008 8:57 am
it changed here around late 98 early 99
Re: How can i tell? by FRN-71E on Fri Aug 15, 2008 8:59 am
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: How can i tell? by Red Oktober on Fri Aug 15, 2008 9:02 am
they've got them (sort of) in the states ...under the "Isuzu Rodeo" badge :D
Re: How can i tell? by Sir-Doris on Fri Aug 15, 2008 6:15 pm
The long wheel base is called a Holden/Isuzu Frontera. It was available with the 2.6 or 3.2 petrol engines both of which were 6 cylinder variants and possibly the 2.8 diseisel turbo.
The Isuzu Trooper is called Jackaroo in Australia.
Re: How can i tell? by FRN-71E on Fri Aug 15, 2008 11:02 pm
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: How can i tell? by Drift on Fri Aug 15, 2008 11:07 pm
From 92 to 95 all the Fronteras here had leaf suspension and rear drum brakes, then from 95 on they all went coil suspension with disc brakes all round.
The A series continued to 1998 when the B Series new shape started to appear in the UK.
I think the confusion is the A series had both coil and leaf suspension.
Hope this helps bud :D
Re: How can i tell? by FRN-71E on Fri Aug 15, 2008 11:36 pm
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: How can i tell? by Sir-Doris on Sat Aug 16, 2008 2:11 am
Sounds like its the same as the USA, Frontera's (Amigo-SWB and Rodeo-LWB) there they didnt get coil rear ends until I think 98' on, which would be the new shape.
