Frontera Technical Support • View topic - IM LOOKING FOR?
IM LOOKING FOR?
IM LOOKING FOR? by FRN-71E on Thu Aug 14, 2008 12:54 pm
hey guys i found this on youtube and was wondering does anyone have any spec;s or know whos it is? it just looks awesome i wanna know what hes done to it thanks
FRN-71E
Modifications: * 3inch suspention lift
* 1inch body lift
* 30x15r16 all terrains
* Dinted panels
* manual locking hubs!
* SIG front locker
Re: IM LOOKING FOR? by Trugga on Thu Aug 14, 2008 1:04 pm
I don't recognise it.
Do you have a link to the YouTube video ? - we might recognise the person who sumbitted the video.
Re: IM LOOKING FOR? by nitromotor on Thu Aug 14, 2008 1:06 pm
Moved to general section
Re: IM LOOKING FOR? by FRN-71E on Thu Aug 14, 2008 1:09 pm
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: IM LOOKING FOR? by Red Oktober on Thu Aug 14, 2008 2:18 pm
The owner of that sport isn't a member on here now ...he is called "Kevin Prentice" ...not sure if he's still active on any other sites or not
I'm told the truck was broken for spares
Re: IM LOOKING FOR? by paul higgi on Thu Aug 14, 2008 4:36 pm
paul higgi
3" body lift
5;38 diffs front /rear
ARB compressor
Superwinch EPI 9
Revolution transfer gears
Cb
Surco roof rack
4 x spotlamps
Rear spotlamp
Rear tubular bumper
Isuzu trooper rear axle
Isuzu trooper front axle
Safari snorkel / RHS SS25HF
Arches cut and welded
trooper transfer case housing
Hydraulic handbrake
AVM manual locking hubs
3" Flexi Arch Kit
Re: IM LOOKING FOR? by Road Hog on Thu Aug 14, 2008 7:22 pm
FRN-71E what has happened to your avatar ??
Re: IM LOOKING FOR? by FRN-71E on Fri Aug 15, 2008 12:01 am
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: IM LOOKING FOR? by Drift on Fri Aug 15, 2008 12:24 am
Yours is on coils ? that other one is on leaf springs :wink:
Re: IM LOOKING FOR? by FRN-71E on Fri Aug 15, 2008 1:55 am
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: IM LOOKING FOR? by Drift on Fri Aug 15, 2008 3:10 am
I have trooper plus 2" coils in mine from Pro Comp and have wound the torsion bars up 2" and done a ball joint flip to get some camber back, though I needed to add an extra 3mm shim behind the top suspension arm to bring it back in line as I wanted it big enough to get 32" tyres under without a body lift, its funny as my wheels went \---/ rather than /---\ which they should have done with a lift, so I suppose if you get the opposite effect than me you could remove a shim if the ball joint flip throws it out more, though that can increase downward travel that is lost in the torsion bar wind up.
also again, its worth trimming the upper bump stop to gain travel.
I have a coil retainers given to me by a good friend on here Alex here is a pic.
Also a good source for parts in your part of the world is here
http://clubisuzu.proboards29.com/index.cgi
It says Isuzu but covers Fronteras, a guy called Geeves is the local guru, tell him I said Hi :lol:
Re: IM LOOKING FOR? by Sir-Doris on Fri Aug 15, 2008 4:04 am
OI... DRIFT... With a lift mate the wheels will go like \__/ because the lower control arms are shorter then the top ones. The ball joint flip will push the top ball joint out even further the higher you go. Think of it as trying to fit 2 railway curves together, like this (( if you were to push them together they wouldnt fit. For them to fit the inner curve has to have a tighter radius.
Hang on, Im drawing a picture.....
Here we go:
Does that make sense?
Sorry dude :D :D :D I just had to do that :D :D :D
Re: IM LOOKING FOR? by FRN-71E on Fri Aug 15, 2008 4:57 am
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: IM LOOKING FOR? by Drift on Fri Aug 15, 2008 8:42 pm
Ill get you some pics in the morning :wink:
Not on mine Phil, me and Bernie had to do surgery to fix it :lol: bloody weird car mine and the bolt heads are made of putty :evil: :lol:
Re: IM LOOKING FOR? by Trugga on Fri Aug 15, 2008 10:46 pm
Re: IM LOOKING FOR? by Sir-Doris on Sat Aug 16, 2008 12:15 am
Cant be lawrence, because the bottom arms are shorter then the top arms if you measure them from the axis point to the centreline of the ball joint. So the bottom arm scribes a smaller radius.
Re: IM LOOKING FOR? by Drift on Sat Aug 16, 2008 12:20 am
Adding the extra 3mm shim to the top each side sorted my \---/ out, though the ball joints are flipped, this could have contributed.
Just to confirm, its outside edge tyre wear.
Its transformed the handling to.
Re: IM LOOKING FOR? by FRN-71E on Sat Aug 16, 2008 1:38 am
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
Re: IM LOOKING FOR? by Drift on Sat Aug 16, 2008 1:41 am
Number 21 on this picture :wink:
Re: IM LOOKING FOR? by FRN-71E on Sat Aug 16, 2008 2:18 am
FRN-71E
* 1inch body lift
* Dinted panels
* SIG front locker
