Frontera Technical Support • View topic - 2.8 rear diff leaking
2.8 rear diff leaking by Mossey on Thu Aug 07, 2008 11:59 am
I have just noticed that the rear diff on my 2.8 is leaking, judjing by the look of it I will have to replace it.
Does anyone have one they could sell or would a trooper diff cover fit as I'm sure there are a few in a breaker near me???
Mossey
Re: 2.8 rear diff leaking by Rifleman on Thu Aug 07, 2008 12:13 pm
If the cover is rotten, can't you just replace it?
Re: 2.8 rear diff leaking by alex on Thu Aug 07, 2008 12:14 pm
Depends on the state of it, if its porous then its a new one, if its punctured a good welder can sort it. Stand to be corrected, but I think in general the trooper diff is different.
Re: 2.8 rear diff leaking by Road Hog on Thu Aug 07, 2008 12:20 pm
They are still available new from Vx
Re: 2.8 rear diff leaking by Mossey on Thu Aug 07, 2008 12:39 pm
any idea how much only funds are a bit tight at the mo
Mossey
Re: 2.8 rear diff leaking by Red Oktober on Thu Aug 07, 2008 12:47 pm
they are about 50 ish quid brand new
Re: 2.8 rear diff leaking by FUDDY MUCKER on Thu Aug 07, 2008 1:15 pm
Re: 2.8 rear diff leaking by Mossey on Thu Aug 07, 2008 1:51 pm
That may be my next step, as far as welding goes i'm fairly good when there is enough metal to weld to but miracles usually are not my forte.
I was hoping someone would have a spare that I could just swap over.
Mossey
Re: 2.8 rear diff leaking by Mossey on Thu Aug 07, 2008 3:12 pm
a friend of mine has a rear axle from a 2.4 - will that diff cover fit my 2.8???
Mossey
Re: 2.8 rear diff leaking by Sir-Doris on Thu Aug 07, 2008 3:34 pm
Should do. The only thing I could think of that might be different is the brake bias valve bracket, but that only bolts onto the studs that are securing the cover anyway. So would imagine all the covers are the same.
Re: 2.8 rear diff leaking by alex on Fri Aug 08, 2008 2:12 pm
Sorry, but the 2.8 is unique, it wont fit. As for welders, no sorry :dance: will watch from distance if you get pulled Sunday :twisted:
Re: 2.8 rear diff leaking by Mossey on Fri Aug 08, 2008 3:41 pm
Thanks Alex, not quite the answer I was looking for but thanks all the same :)
Mossey
Re: 2.8 rear diff leaking by Drift on Sat Aug 09, 2008 10:31 pm
Trooper deffo different, if its the seal leaking it can be resealed, but likely it will need replacing, looking around £60 these day main deal, it aint worth getting second hand.
See here for more info.
viewtopic.php?f=41&t=984
