Frontera Technical Support • View topic - its making noises
its making noises
its making noises by b19sin on Tue Aug 05, 2008 11:03 pm
hi
I noticed tonight a noise that when i turned the key off something was buzzing when i lifted the bonett there was water trikleing into the resivour(<erm) and i had to disconect the battery to stop it what could this be?
many thanks, Simon
b19sin
Modifications: roof rack
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
boot full of tools & equipment (eg spade, hand winch)
Re: its making noises by andysd1 on Wed Aug 06, 2008 1:40 am
on the 2.3 we have a pre water pump, which starts flowing water on ignition, dont know about the other engines, if its running when the ignition is of check the pump,
located just beside the header tank, there is a plug runing to it you can unplug if you want to,
Re: its making noises by b19sin on Wed Aug 06, 2008 2:58 pm
thanks Andy!
yes there is a plug and it does stop it so can i leave this out or do i need it?
thanks, Simon
b19sin
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
Re: its making noises by andysd1 on Wed Aug 06, 2008 4:05 pm
Re: its making noises by andysd1 on Wed Aug 06, 2008 4:07 pm
just a thought check your fues as i think that comes on when the fuse is blown
