Frontera Technical Support • View topic - Lower ball jonts made easy
Lower ball jonts made easy by alex on Mon Aug 04, 2008 4:58 pm
Thats right, stumbled on an easy fix, no heat, no massive beatings (well when the beatings didnt work).
With wheel removed and axle stand under front chassis, remove big castleated nut. Then using a trolley jack under the bolt, jack up pretty high (dont relax the torsions, they are your friend here). Get a standard ball joint splitter (the hammer in version), you may need to widen it by hammering over a bar or grinding a lead in to allow the ball joint to do it.
Hammer in the ball joint separator as hard as you can (a sawn off sledge here can help). When its in as far as it will and your sure its well embeded check the axle stand will catch the car and drop the jack quickish.
With the arm up a few inches the ball joints body was parallel to the axle carrier, as the arm articulates the body of the ball joint needs to rotate too, but cant because the splitter is in between the two. It simply pulled the ball joint out with a pop (okay the first actually split the splitter :oops: ) the second was more well behaved and hadnt been abused with hammer previously.
End result, no swear box used, no heat, no beating required.
Just the regular ball ache or getting around everything to remove and replace the thing I dont have a shortcut for.
Shame really, wanted to jase's face when I took a burner to his car :twisted:
Re: Lower ball jonts made easy by andysd1 on Mon Aug 04, 2008 5:48 pm
when puting it back to gether i used long bolts about 8" long, when i pulled it in to positon i replaced the long one for the proper ones,
Re: Lower ball jonts made easy by alex on Mon Aug 04, 2008 6:12 pm
How did you get em around the cv cup? we ended up using a bottle jack under the plate and getting it flush with the arm.
Re: Lower ball jonts made easy by FUDDY MUCKER on Mon Aug 04, 2008 7:19 pm
May I take this opportunity to thank ALEX, Yet again, for giving his time up to master the very tired and worn ball joints on me truck.
Many thanks MATE. :clap: :clap: :clap:
It was a pleasure to drive back home in a quite, non squeeking Frontera.
Got to admit, after the several hours trying to master the first side, the option of doing the other side seemed quite daunting, but in fairness, actually cracking of the ball joint to no longer than 10 minutes, it is all the other stuff you have to undo or remove to get around.
Hopefully, I won't ever need to do them again, but should the need to come off, then everything was copper greased prior to refitting, so should be the 15 minute job :wink: as some other member pointed out as the time it should take to do one side. :shock: :shock: :shock:
Yeah right !!!! I challenge anyone to do one in under an hour, even after everything is greased up.
Re: Lower ball jonts made easy by bobbinsjob on Mon Aug 04, 2008 7:23 pm
can you do it all again and take some photos Alex :lol: :lol: :lol:
Re: Lower ball jonts made easy by andysd1 on Mon Aug 04, 2008 8:18 pm
Re: Lower ball jonts made easy by alex on Mon Aug 04, 2008 10:27 pm
:party: Dont worry Andy, we all av em.
Jase, pleasure mate, we all help one another round here. Hows Bobbies head?
Re: Lower ball jonts made easy by FUDDY MUCKER on Mon Aug 04, 2008 10:48 pm
Re: Lower ball jonts made easy by 4x4 bobby on Tue Aug 05, 2008 1:23 pm
