Frontera Technical Support • View topic - Oil leak, need advise
Oil leak, need advise by Icemahn on Fri Aug 01, 2008 9:00 pm
Noticed a bit of oil leaking just under the end of the exhaust manifold, just above the oil stick. Engine is 2.2 petrol LWB fronty B. only happens on very high revs otherwise dry. Has been loosing oil for a while. Please help :(
Icemahn
Re: Oil leak, need advise by andysd1 on Fri Aug 01, 2008 9:40 pm
dont rev so high, sorry i will get my coat
Re: Oil leak, need advise by andysd1 on Fri Aug 01, 2008 9:41 pm
is it coming from head or rocker cover
Re: Oil leak, need advise by jellybaby on Fri Aug 01, 2008 9:48 pm
i've got loads of oil leeks that's why it's called the 2.0 thats the ammount of oil it uses a day :roll:
my rocker cover leaks on my swb would that cause it to appere to use a load of oil.
of could it be the rear oil seal around the crank shaft ??
Re: Oil leak, need advise by andysd1 on Fri Aug 01, 2008 9:50 pm
Re: Oil leak, need advise by screwyuk on Sat Aug 02, 2008 12:17 pm
Try cleaning the breathers on the rocker box top including the small pipe that goes to the air intake/manifold device,make sure the pipe is clear and the connection they go to are also clear.
screwyuk
Modifications: frontera sold :-(
