Frontera Technical Support • View topic - failed mot
failed mot
failed mot by charlie01 on Fri Jul 25, 2008 8:36 pm
dont beeleive it it should of failed on os lower ball joint ,steering idlear pivot well noisey but no only done me 4 emissions cat and lambda great id rather do a ball joint
charlie01
Re: failed mot by woodwizzard on Fri Jul 25, 2008 10:36 pm
Should be able to pick up a lambda for around £30 and I think some people have had success with that catclean stuff, but I don't know anything about it myself.
Re: failed mot by john (smifffy) on Sat Jul 26, 2008 8:11 am
cataclean is a good product you put it in the last 10 to 15 ltrs of fuel and run it for 20 min and it cleans from the tank through to the cat
i always put a bottle through when i'm taking it for an mot i even had a garage think there machine was broken cause the reading was that low
its about £12 a bottle
you can get a lambada sensor from most good car shops you might have to order it
Manufacturer VAUXHALL
Model Frontera
Stroke Ltr 2.2
Stroke cc 2198
Horsepower KW 100
Horsepower PK/PS/CV 135.96
Fuel System M
Number Of Cylinders 4
Engine Code X22XE
From 1995-04
Till 1998-08
intermotor
Part number 16391
Part type Oxygen Sensor
Replaces
Bosch 0258003448
Lucas LEB214
NTK 0193
NTK OZA446-E40
Opel 90499265
Opel 90499266
Opel 90499267
Opel 90509169
Opel 90509274
Renault 7700854506
Renault 7700867295
Vehicles Using Part 16391
OPEL Frontera 2.0
OPEL Frontera 2.2
OPEL Omega 2.5
OPEL Omega 3.0
OPEL Sintra 3.0
OPEL Vectra 2.5
VAUXHALL Frontera 2.0
VAUXHALL Frontera 2.2
VAUXHALL Omega 2.5
VAUXHALL Omega 3.0
VAUXHALL Sintra 3.0
VAUXHALL Vectra 2.5
Re: failed mot by charlie01 on Sat Jul 26, 2008 8:28 pm
cheers guys for advice o2 sensor 35 quid not bad due 2 head gasket re new cat knackerd due 2 to much steam also coupling flange 2 exhaust rotten got cat 4 £106 v good
charlie01
Re: failed mot by john (smifffy) on Sat Jul 26, 2008 9:17 pm
Re: failed mot by charlie01 on Sun Jul 27, 2008 8:46 pm
cheers smiffy i got it down from £205 to £106 aint got time to by on line goin away needed 1 pronto but that makes £106 LOOK DAFT TA .
charlie01
