Frontera Technical Support • View topic - erm glue
erm glue
erm glue by b19sin on Wed Jul 09, 2008 5:28 pm
hi guys n gals, what do you think of glued cv boot as i when to buy my real boot and they offerd me one so now dont now what to do because if they glued ones work it will save me lots of time and effort.
thanks Simon
b19sin
Modifications: roof rack
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
boot full of tools & equipment (eg spade, hand winch)
Re: erm glue by Drift on Wed Jul 09, 2008 5:53 pm
I always use them, well twice once each side :lol:
Been used lots in 4wd no problems, took 20 minutes to fit 8) including time to take the wheel off :wink:
Its that easy I carry a spare in the boot just in case.
Re: erm glue by Red Oktober on Wed Jul 09, 2008 6:12 pm
Thats the cheats way out ..... ..
to do it properly you need to take the half shaft to pieces :D
Re: erm glue by Rifleman on Wed Jul 09, 2008 6:36 pm
Hate them myself, had used them a couple of times but eventually had to the job properly, causing more time and money.
Wont use them again.
Re: erm glue by philmotman on Wed Jul 09, 2008 6:39 pm
i wouldnt use the glue on cv boots not the best option(imo).you can get a stetchy boot from a motor factors (gt or gl)with these you dont need to take the cv joint off the shaft ,but you still need to remove the shaft from the hub.
phil
philmotman
Re: erm glue by Drift on Wed Jul 09, 2008 7:27 pm
I guess Im just charmed :D
Re: erm glue by bobbinsjob on Thu Jul 10, 2008 6:34 am
last time i did the cv boots I used the propper ones and one thing is for certain, next time i will be fitting gluey ones.
(A sharp tap with a plastic mallet will separate the CV joint :lol: :lol: :lol: :lol: make it half an hour trying to kill it with a copper hide :twisted: :twisted: )
Re: erm glue by nitromotor on Thu Jul 10, 2008 9:56 am
The stretchy boots are ok to use but you still need to separate the bottom ball joint to fit.
I fit a sticky boot on each side without problem, used for P+P fording, laning and the usual V6 tarmac performance.
One side developed a pin hole after about 10k, not an issue but now changed for stretchy, left the other side.
10k from a sticky boot exceeded my expectations by about 9.75k
Will I use sticky boots again..., yes I have one on the shelf waiting....
I don't like fighting to remove the bottom BJ so for a pain free repair the sticky wins, but thay will not last long.
also if you get the slightest oil contamination on the boot when gluing thay will split very quick in deed, if that happens then you have just waisted your time as the extra time to re do negates the quick aspect and you may as well fit a stretchy boot
Re: erm glue by Drift on Thu Jul 10, 2008 10:04 am
They are great I think, I would rather fit two split boots than one normal boot, just to add mine has been through two MOT's.
The way I see it if a tree branch is going to rip your boot, well .. its going to rip your boot so the split ones save all the hassle.
Anyway the front drive shafts only spin in 4wd so its not like its getting hammered on everyday roads :wink:
Re: erm glue by Red Oktober on Thu Jul 10, 2008 10:07 am
the split boots are cheating :roll: :lol: :lol: :lol: :lol: :lol:
personally i prefer the proper ones where you have to dismantle the half-shafts :D :D :D :D :D :D
Re: erm glue by alex on Thu Jul 10, 2008 10:11 am
I have to say as Drift the glue exceeded my expectations. I have a split normal I will replace soon with a glue, and now Ive done a few miles 4x4 with the glue on I will be buying 2 so I have a spare in the boot.
Having done one i can see how rushing or carelessness could lead to issues, you willneed to be patient, but it will pay off. The guy whosold it me hates them :lol: Cant wait tobuy 2 more off him.
Re: erm glue by nitromotor on Thu Jul 10, 2008 10:12 am
The people that hate them are the ones that dont keep the joint free of contamination and rush the job
Re: erm glue by Drift on Thu Jul 10, 2008 10:30 am
Im a ham handed clutz and even I can get them right, ok I do stick my fingers together now and then but hey, I should put the gloves on that come with them :lol:
Re: erm glue by nitromotor on Thu Jul 10, 2008 10:36 am
When I did mine I used a mile of blue cloth, 2 tins of brake cleaner and about 10 pairs of gloves :lol:
Re: erm glue by Rifleman on Thu Jul 10, 2008 11:03 am
Re: erm glue by alex on Thu Jul 10, 2008 6:53 pm
Well did one dinner time, in the rain :x
Luckily it went well, not as well as before but likely more due to weather and the fact it was an inner and needed wrestling around the gazzillion bits in the way that stop you getting mits around it. Still managed to fetch and install in a lunch hour so its positive feedbackfromme again.
Re: erm glue by b19sin on Wed Jul 16, 2008 12:45 am
well just to let you know i used it and took the cheats way out the hardest part of it was getting the old grease off/out.
thanks Simon
b19sin
roof lights
spot lights
snorkal
31" mud tyers
recovery shackles
2"lift
Re: erm glue by Drift on Wed Jul 16, 2008 12:58 am
See easy aint it :lol:
Re: erm glue by Trugga on Wed Jul 16, 2008 7:18 am
I need to replace one of the inner gaiters on the BBB.
I will be using the proper boots (stretchy), rather than split.
I would imagine the split boots are ok for "field repairs", but is it possible to service the pot joint and get all the crud out with the shaft in situ ?
Re: erm glue by Red Oktober on Wed Jul 16, 2008 9:54 am
see Here
