Frontera Technical Support • View topic - Diesel Choice?
Diesel Choice?
Diesel Choice? by monzaiain on Sat Jul 05, 2008 7:56 pm
Hi folks,
Im looking to get a LWB diesel, i was wondering what is the best engine choice overall??
Im looking for around a 96/7 model...i would think the 2.8 Isuzu would be best,but please correct me if not...also what price should i be looking to pay?
any help apprecieated.Thanks
monzaiain
Re: Diesel Choice? by Red Oktober on Sat Jul 05, 2008 8:17 pm
yup ...2.8tdi :D :D :D :D :D :D :D
Re: Diesel Choice? by Drift on Sat Jul 05, 2008 8:18 pm
The 2.8 would be simpler to work on than the 2.5 which is a bit more powerful but a very technical engine.
The 2.8 are only available 95 to 96 the 2.5 from 96 to 98 :wink:
Re: Diesel Choice? by Trugga on Sat Jul 05, 2008 8:20 pm
2.8TDI
A little over 6 years ago I had determined through research that the 2.8 gave the best mpg and the best 0-60 of all the estates - that's what I went for and have not looked back.
Re: Diesel Choice? by woodwizzard on Sat Jul 05, 2008 8:20 pm
Not got any experience of the 2.5 so can't comment but a few on here have them so will no doubt chip in at some point. The 2.8 seems to be regarded as the strongest, most reliable of the diesels and fairly basic so relativly easy to maintain. I have just bought a swb 2.8 so am hoping that what I have just said is true :lol: Some of the others with more knowledge will give you more imfo on the other models.
Re: Diesel Choice? by monzaiain on Sat Jul 05, 2008 8:30 pm
Great thanks guys... :D
I thought with it being the Isuzu it would be the best...
Thanks for the info on available years as well...
Ive seen a couple but to be honest i was a bit sceptical about paying £495 for one..or £695 for another!
I thought at that price it would be a bag of yon stuff! :lol:
Can i also ask folks,what to look out for when looking at one??
monzaiain
Re: Diesel Choice? by Trugga on Sat Jul 05, 2008 8:42 pm
You need to look after the 2.8, with regular oil changes (around 3000 miles)
The engine is interference (pistons overlap the valves), so if you can't determine the last time the cam belt was changed, get it sorted asap (change at no more than 40,000 miles)
Vacuum pipes are prone to perishing/splitting at this age (they were available from May 1995 to September 1996). This will manifest problems in cold starting and fuel consumption (amongst other things)
Turbo charges have failed - listen for screaming or if you have the opportunity, take the front intake pipe off and check the impellor shaft for play (there should not be any) new turbo about £450, 2nd hand from a scrapper (if you can find one, £50).
EGR system is probably coked up, but most people here seem happy to blank them off. On a good engine (ie, my new one), you can see/hear them chattering away at idle.
Check the quality of the air hoses - a split/porous one will reduce power.
Erratic oil pressure gauge reading is most likely a loose connection on the sender unit - easily fixable.
There's a little to think about - I'm sure there'll be more from others later.
Re: Diesel Choice? by monzaiain on Sat Jul 05, 2008 8:44 pm
Great info there Trugga....thanks mate :D
monzaiain
Re: Diesel Choice? by Road Hog on Sun Jul 06, 2008 12:40 am
Re: Diesel Choice? by andysd1 on Sun Jul 06, 2008 2:22 am
Re: Diesel Choice? by Drift on Sun Jul 06, 2008 9:44 am
2.3 where stopped about 94 early 95
Re: Diesel Choice? by Road Hog on Sun Jul 06, 2008 9:54 am
Re: Diesel Choice? by Drift on Sun Jul 06, 2008 9:57 am
:lol: :lol: :lol: :lol:
Re: Diesel Choice? by Drift on Sun Jul 06, 2008 9:59 am
2.3 74 kw at 4200rpm Torque 215 at full revs ( 2.3dtr no figure given)
2.8 82.2 kw at 3600 rpm 242 torque at 2100 RPM( 4JB TC )
2.5 85 kw at 3600 torque 260 at 1800 revs (VM41 boat engine when running)
2.2DTI 88kw at 3800rpm torque 280 at 1500 to 2750 rpm ( x22DTH)
2.2DTI 85kw at 3800rpm torque 260 at 1900 rpm (y22DTH)
