Frontera Technical Support • View topic - got one at last
got one at last
got one at last by kingfisher on Thu Jul 03, 2008 12:12 am
got me another engine at last , it was from giffords in brierley hill , before i get it fitted is there anything i should do before , i will be replacing the timing belt .by the way its a c2ione engine . thanks
kingfisher
Vehicle Name: The money pit
Re: got one at last by stu on Thu Jul 03, 2008 2:28 am
well done mate :D i would replace all the belts and drop the oil while its out the car , probably easier .
Re: got one at last by Drift on Thu Jul 03, 2008 6:06 pm
And replace your clutch and rear crank seal while its easy to do :wink:
Re: got one at last by woodwizzard on Thu Jul 03, 2008 6:56 pm
Whooppee!! Ste is picking on someone else's wallet :dance: :dance:
Re: got one at last by kingfisher on Thu Jul 03, 2008 7:38 pm
do you think i should replace the head gasket , :?:
kingfisher
Re: got one at last by Drift on Thu Jul 03, 2008 8:02 pm
Re: got one at last by Alfie on Thu Jul 03, 2008 9:29 pm
Well done mate. Are you going to put it in yourself? If you need help give us a shout. I'm sure some of the local members would be willing to lend a hand.
Thingsto replace:-Clutch plate
Crank oil seal
Timing belt
Spark plugs
Oil and flter
Things to check:- Water pump
Oil pump
Distrubuter and leads
Sump gasket
Clutch release bearing
Condition of all bets/pulleys
I cant think of any thing else at the moment but someone else should be along in a while with more info for you. :D :D
Vehicle Name: Dino
Re: got one at last by kingfisher on Thu Jul 03, 2008 11:45 pm
thanks for the advice guys , i,ll get down the local car spares on sat ,thanks for the offer alf and the list :wink: but my dads next door neighbour as offererd to put it in , thanks again mick ( i,m so glad i joined you guys ) thanks mick
kingfisher
Re: got one at last by andysd1 on Fri Jul 04, 2008 1:49 am
Re: got one at last by Postfinder on Fri Jul 04, 2008 8:21 am
Postfinder
Modifications: The biggest hazard to my truck is Me.
"there is nothing wrong with getting a Sport airborne, bad things only happen when you land"!!
