Frontera Technical Support • View topic - Black thing under OSF wing?
Black thing under OSF wing? by mpjbiker on Mon Jun 30, 2008 4:11 pm
Hi all, just been looking at the damage to my SWB A sport after a cow wandered into the road. I took off the plastic inner wing panel (with the screws which are carefully designed never to come undone!) to see if there was any damage to the inner wing panel up near the headlight. Ther is what looks like some sort of tank up there-can someone tell me what it is, please?
Cheers, Martin.
mpjbiker
Re: Black thing under OSF wing? by Red Oktober on Mon Jun 30, 2008 4:24 pm
Does it look like this .....
it's a vacuum reservoir for the vac system
Re: Black thing under OSF wing? by mpjbiker on Mon Jun 30, 2008 5:26 pm
Hi mate, cheers for quick reply-difficult to tell with the wing in place, but I'd say so. Is it likely to have been damaged by the impact? Truck drives as usual, so I'd guess not?
mpjbiker
Re: Black thing under OSF wing? by Red Oktober on Mon Jun 30, 2008 5:37 pm
nope .....you won't have damaged it
Re: Black thing under OSF wing? by skywalker on Mon Jun 30, 2008 9:58 pm
Hi Red Oktober,
Ive Just had the plastic liner out of mine and it hasnt got a vac resevoir?
I did remove the front wing in my little altercation with the unimog but i just flatened and peeled back the wing but i didnt see one of those there and not when i gave it to my mate to fit the new wing and door.
Any ideas?
A very worried Skywalker :(
skywalker
Modifications: Uprated Shock Absorbers,Calmini+2" lift shackles General Grabber AT2 Tyres ,CB Radio 3 replacement gearboxes so far and another recon one to go in !
Lots of stickers! and Scratches
Re: Black thing under OSF wing? by Drift on Mon Jun 30, 2008 10:06 pm
I havent checked but pretty sure the brake servo is different on 20L as the 2.8 is run from the alternator so the gubbins will be different.
Re: Black thing under OSF wing? by Red Oktober on Mon Jun 30, 2008 10:46 pm
the vac tanks are on the 2.5tds's and 2.8tdi's ....not sure about the 2.3td's
Re: Black thing under OSF wing? by andysd1 on Mon Jun 30, 2008 11:08 pm
Re: Black thing under OSF wing? by Red Oktober on Mon Jun 30, 2008 11:21 pm
Re: Black thing under OSF wing? by skywalker on Wed Jul 02, 2008 10:42 pm
Hello Gang,
Thanx, Panic over. I guess 2.0i 's dont have them.
However i think mines just done a wheel bearing. Hey Ho.
skywalker
Users browsing this forum: No registered users and 44 guests
