Frontera Technical Support • View topic - EGR valve
EGR valve
EGR valve by TESCO.COM on Thu Jun 26, 2008 3:21 pm
tried replacing said valve but would not fit got one bolt in but other refused to line up then noticed it was angled to the block as the other one was angled away to the firewall does the whole unit need replacing or can you change the top.
TESCO.COM
Vehicle Name: TAZ
Re: erg valve by Sir-Doris on Thu Jun 26, 2008 3:30 pm
Think the whole unit needs replacing.
Re: erg valve by TESCO.COM on Thu Jun 26, 2008 3:41 pm
did you notice the spelling mistake thanks for your reply i will try again
TESCO.COM
Vehicle Name: TAZ
Re: erg valve by alex on Thu Jun 26, 2008 5:15 pm
What engine?
Re: erg valve by Trugga on Thu Jun 26, 2008 8:40 pm
Re: erg valve by TESCO.COM on Sat Jun 28, 2008 2:17 pm
the engine is a 2.2i petrol p reg . only using a library computer so i am now and again able to answer
TESCO.COM
Vehicle Name: TAZ
Re: EGR valve by Sir-Doris on Sun Jun 29, 2008 1:49 am
same engine as mine (more or less) so yes, the egr valve is a sealed unit. probably around the hundred quid mark from vauxhall possibly + VAT. They are available on ebay from time to time for 50 to 80 quid.
Re: EGR valve by john (smifffy) on Sun Jun 29, 2008 10:18 am
you could try these people they might be able to help with new one not sure on price's
http://www.emissioncontrols.co.uk/page. ... 0%20Valves
Re: EGR valve by f8rdy on Sun Jun 29, 2008 1:23 pm
ive got the EGR Valve and ignition module off a 2.0 vectra X20XEV if that would be any good for you? Anyone know if they match?
Its used and cant guarantee that its working but didnt have any probs i was aware of when i took it off the car.
f8rdy
Modifications: 2.0 16v Engine Transplant, CB Fitted, Wrap Around Bullbar (Irmscher?), Grey Painted Wheels, Shiny Red Valve Caps!
NOTE: Although my fronty is on a V plate, its a Frontera 'A' shape (as its an Opel) and has the dash with the radio at the top!
Re: EGR valve by Sir-Doris on Mon Jun 30, 2008 2:13 am
Compare pics, I know that the 2liter xe engine uses the same one.
Re: EGR valve by f8rdy on Mon Jun 30, 2008 6:08 pm
its very slightly different to the one i had on my 2.2 but thats because mines an opel so for some reason they used a different part!
f8rdy
