Frontera Technical Support • View topic - Where do you mount your CB Aeriel ?
Where do you mount your CB Aeriel ? by ukcobra on Wed Jun 25, 2008 3:47 pm
I used to mount mine on the Front bullbar, when using the long whip, and on the roof using the smaller mag mount.
One of the vehicles I contemplated buying had some sort of bracket fitted to the rear door hinge, which was kind of nice because it was hardly noticeable when the whip was removed.
As I'll be refitting my CB next week to my new Fronty (hopefully) I'd like some alternative location advice.
Regards
Mark
ukcobra
Modifications: 96 2.0 S SWB
Old Man Emu 2" Lift
Mods to fit :
Mods to come:
Winch
Re: Where do you mount your CB Aeriel ? by country_Est on Wed Jun 25, 2008 3:51 pm
Just for total ignorance I have my MAG mount one mounted behind the rear seat INSIDE the fronty.
Dont know what its like for range as its only used for lanning and seems to be Ok for the range the lead truck gets to.
Tried it on the roof and on the bonnet but it kept getting knocked off when on tight bushy lanes.
Trev
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: Where do you mount your CB Aeriel ? by Red Oktober on Wed Jun 25, 2008 3:57 pm
i had mine on the bullbars :wink: ..
but now my bullbars won't fit ......i've mounted it on the roof
Re: Where do you mount your CB Aeriel ? by Alchamist on Wed Jun 25, 2008 4:00 pm
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Mines here now its working too! :!: :D
Had to remove the mounting bolt for the roof rails and remove the paint. Fit nice clean flat washer beneath a new nut (M8 standard nut) Also removed some of the powder coating from the ally roof bar and the roof rail to ensure a good grounding.
Now the aerial is tuned in it seems to work fine.
"metallic brown" 2.2eco LWB "A"1999 & Black 2.2DTi LWB "B"2003
the way forward is back the way you came
Wneiljohnson47
Re: Where do you mount your CB Aeriel ? by zebadee on Wed Jun 25, 2008 6:08 pm
The best place is in the middle of the roof, this gives you the best ground plane (earth) but most of all swr you cb in properly otherwise you will knacker it quicker than you bought it ! the lower the swr reading the better.
Dazza.
Boing Said Zebadee !! B***cks said Doogle !!
can somebody stop this roundabout of life its driving me nucking futs !!!
zebadee
Model: 2.0i Sport Niagra 3dr
Re: Where do you mount your CB Aeriel ? by Sir-Doris on Wed Jun 25, 2008 6:09 pm
7" Mag mount on the roof. Have gone under plenty of low lying trees and wot nots without a hitch. With mag mounts a whippy coil (spring shaped at the base) aerial is a good start. I only use my cb for greenlaning so dont need a permanent fixture.
If you read the postings RE CBs in ICE (on Fog forum) You'll get the best advice. Thats where I got my info from. Only the best from the best!
Wneiljohnson47
Re: Where do you mount your CB Aeriel ? by alex on Wed Jun 25, 2008 7:42 pm
I got a huge twig on the roof rack, keeps fighting with the Holly tree in my front drive. Used to go off the Bullbar as its nice and easy to bring it inside the cab through the grometts in the passenger bulkhead.
Re: Where do you mount your CB Aeriel ? by Rifleman on Wed Jun 25, 2008 8:42 pm
Mines will be going on my new roofrack, but there are loads of choices on ICE including roof rail mounts if you dont want to drill or do damage. Depending on where you mount it, try to bring the cable in through an existing grommet rather than drilling or flattening in the door check.
Re: Where do you mount your CB Aeriel ? by Luke on Wed Jun 25, 2008 10:04 pm
Mine is mag mounted on the roof, only knocked it off once when I went under a height restriction at the local tip. :D
1995 LWB 3.1TD now sold
2003 LWB 3.2v6
Luke
Re: Where do you mount your CB Aeriel ? by nitromotor on Wed Jun 25, 2008 10:51 pm
Re: Where do you mount your CB Aeriel ? by zebadee on Wed Jun 25, 2008 11:10 pm
Totally agree with Nitro I have a Siro mega watt 4000 on my fronty i hit a low branch the other day(ON ROAD) at about 50mph and only just did it rip the mag mount from the roof so there is no way when lanning you would rip it off, so if you don't mind spending a bit more on your aerial go for one of these, when it used to be on top of my work vehcile i could hit railway lines with it (not recommended) works vehcile was a volvo fm12 globetrotter !! but the longer your whip the more range you will get.BUT DON'T FORGET TO SWR IT IN !!!
Dazza.
zebadee
Re: Where do you mount your CB Aeriel ? by PaulS on Sat Jun 28, 2008 9:37 pm
Thats mine:
Proud to be Response Member of:
[/color][/b] Image
1994 Frontera Sport in Flame Red 2.0i 8v
PaulS
Modifications: 2" suspension lift, M/T Duelers, Midland Alan 78 Plus Multi CB radio, personalised dents and some rust here and there :)
