Frontera Technical Support • View topic - shows that a good service is worth it
shows that a good service is worth it by nobby on Fri Jun 20, 2008 4:53 pm
Well have just done wales to cornwall,all around and back again (nearly 800miles)in my 2.3 without a glitch. :dance:
In the past ive always used shell helix or valvoline15/50 but have always had the flickery light when hot and temp always went up slightly a bit on hills .
last week gave it the full once over and couldnt get my regular oil so was reccomended some morris oil 15/50 (some may say too thick but im on 160k on my first turbo)..well what a difference :shock: :shock: temp didnt budge and no flickery light even after a 5 hour drive can only assume the other oils where over thinning (so perhaps not all oils with same grade are the same)so I think I will be using this stuff from now on
only dead fish go with the flow!(2.3 im in no rush)
nobby
Glad it all went good for you ... :D :D :D
Re: shows that a good service is worth it by Drift on Fri Jun 20, 2008 6:31 pm
Nice one, I tend to use slightly thick oil in the summer
Re: shows that a good service is worth it by Sir-Doris on Fri Jun 20, 2008 8:03 pm
Agreed, I generally change to 5w/40 when the weather cools down and then back to 10w/40 when it warms up.
Re: shows that a good service is worth it by alex on Fri Jun 20, 2008 10:10 pm
I had a quick snoop around for some 50watt and didnt find any. Will need to persevere methinks.
Re: shows that a good service is worth it by Sir-Doris on Sat Jun 21, 2008 1:07 am
Re: shows that a good service is worth it by nobby on Sat Jun 21, 2008 5:02 pm
a lot of rally boys tend to use the 20/50 or 15/50 so your local tuning shop is a good bet :wink:
nobby
