2.5 TDi - wont rev over 2000rpm
2.5 TDi - wont rev over 2000rpm by JBW on Mon Jun 16, 2008 2:19 pm
Following recent starter motor replacement (during which I had to disconnect battery). I notice a lack of power, almost as if turbo not working. Will accelerate upto 2000 rpm then flattens out.
No smoke, blue black or white. Engine starts fine and revs freely in neutral or in, 1st but wont rev above 2000 rpm in 2nd 3rd or 4th.
Any thoughts? Could it be the ECU is in some sort of 'safe' mode following the disconnection of the battery. How to reset the ECU?
(Hope it's not taken a beating during the overload caused by the starter motor burning out!)
Let's work on the basis that it's something simple first!.
Feedback most welcome.
Ta. JB.
JBW
Model: 2.5 TDS Transglobe 5dr
Modifications: Standard
Re: 2.5 TDi - wont rev over 2000rpm by paul higgi on Wed Jun 18, 2008 6:25 pm
ecu needs resetting, look in 2.5tds section plenty of info
paul higgi
3" body lift
5;38 diffs front /rear
ARB compressor
Superwinch EPI 9
Revolution transfer gears
Cb
Surco roof rack
4 x spotlamps
Rear spotlamp
Rear tubular bumper
Isuzu trooper rear axle
Isuzu trooper front axle
Safari snorkel / RHS SS25HF
Arches cut and welded
trooper transfer case housing
Hydraulic handbrake
AVM manual locking hubs
3" Flexi Arch Kit
Re: 2.5 TDi - wont rev over 2000rpm by JBW on Sun Jun 22, 2008 10:17 pm
Ta Paul.
JBW
Re: 2.5 TDi - wont rev over 2000rpm by JBW on Sat Jun 28, 2008 8:47 pm
Used Car Tools diag tool as recommend by Mike aka awdriver (I think). Sweet. Read codes, made a note of them but shan't bother investigating unless I get further ecu codes. Reset as per instructions said it would. Life is now back to normal in 2.5 TD land...
Thanks Again. To all who read and shunted valuable advice my way.
David aka JB.
JBW
