Frontera Technical Support • View topic - Bad Rattle Help !
Bad Rattle Help !
Bad Rattle Help ! by andyniagra on Wed Jun 11, 2008 7:48 pm
hello all as the title says ive developed a bad rattle/creak/ee ee ee :( dont know what it is.
It creaks relly bad when i pull of or go over a bump, if i bounce on the arch of either side i get an ee ee ee/creak sound ive cleaned all the underside and moving parts and wd40'd but no joy. On the whole it just creaks and its realy doin me head in any ideas to what the cause is ............. :|
andy
frontera sport dead now running a 3.1 trooper MONSTER !!!!!!!!!!
andyniagra
Modifications: Isuzu trooper 3.1 td
* 3" body lift
* 32" bronco grizily claws
* Nudge bar and spots
* +2" coils
* +2" es3000 rear shocks
* rancangoo snorkle
* CB radio
* Ball joint flip
* Modded diff and box breathers
* DVD and sub
and soon to lift the front more ........
Re: Bad Rattle Help ! by Drift on Wed Jun 11, 2008 7:54 pm
Ball joints, could be upper or lower.
Look to see if they have split, inject some grease in the split if they have, the noise should go away, but its only a short term fix, they will need changing sooner rather than later.
Re: Bad Rattle Help ! by Silver Ghost on Wed Jun 11, 2008 8:51 pm
Silver Ghost
Registration Year: 1999/S
Re: Bad Rattle Help ! by Red Oktober on Wed Jun 11, 2008 9:01 pm
make sure you check the antiroll bar bushes too
Re: Bad Rattle Help ! by andyniagra on Wed Jun 11, 2008 9:09 pm
cheers geezers i just looked at the ball joints and both sides bottom joints are split and yous reckon that, that is the cause of all my creaking ..
andyniagra
* 3" body lift
* +2" coils
* rancangoo snorkle
* CB radio
* Ball joint flip
* DVD and sub
Re: Bad Rattle Help ! by Red Oktober on Wed Jun 11, 2008 9:14 pm
my knackered bottom bj's ....
new ones will make quite a bit of difference
Re: Bad Rattle Help ! by Drift on Wed Jun 11, 2008 9:17 pm
Squezze some grease in with a syringe or pump, bet the squeek will disapeare
Re: Bad Rattle Help ! by Mossey on Thu Jun 12, 2008 9:44 am
And what about a picture of your knuckles after trying to replace said ball joints :lol:
I know I lost a few.
Bit of advice if you change them yourself - get some freeze spray, a blow torch and a good prybar, and dont have any children arround whilst doing them (offencive language will occur)
Good luck
Mossey
Re: Bad Rattle Help ! by Silver Ghost on Thu Jun 12, 2008 6:36 pm
Silver Ghost
Re: Bad Rattle Help ! by andyniagra on Thu Jun 12, 2008 7:33 pm
ok i got some things to have a go at im gona pump some grease in see if that helps watch this space....... :D
andyniagra
* 3" body lift
* +2" coils
* rancangoo snorkle
* CB radio
* Ball joint flip
* DVD and sub
Re: Bad Rattle Help ! by Huwwalford on Wed Jun 18, 2008 8:09 pm
Funny thing....I was going to put a post up regarding this as I have just started to hear a similar thing. Mine is almost like a ringing noise though, not grinding. Is it the same thing? Worse when going around a corner on full (ish) lock (This tells me it is the same thing). If so is the cure to pump more grease into the CV boots? Any particular grease? I have had a quick look at the CV boots and there doesn't seem to be any leakage.
As always I would appreciate any info.
Thanks,
Huw.
Owner of 'Maisey Daisey' aka Frontera LWB 2.2DTLi! Model year 2000.
Huwwalford
Vehicle Name: Maisey Daisy
Re: Bad Rattle Help ! by Drift on Wed Jun 18, 2008 8:18 pm
Sounds like a shattered bearing, my inner sounded like that
Re: Bad Rattle Help ! by Huwwalford on Wed Jun 18, 2008 8:53 pm
Drift.....It is a very slight ringing....if I had the radio too loud I wouldn't hear it. Do you think it is just the start?
Huwwalford
Re: Bad Rattle Help ! by Drift on Wed Jun 18, 2008 9:02 pm
At first I thought my circlip was loose in the auto hub but it was still there after I upgraded to manual hubs and chaged the clips, then I thought it was the brake pads clip rattling slightly.
When Tim and I did the lower ball joints we discovered the problem... a disintegrated inner bearing, we fixed that and no noise :wink:
Re: Bad Rattle Help ! by Sir-Doris on Thu Jun 19, 2008 9:43 pm
Mine developed a strange creaking a couple of weeks back, but a good dose of rain last night seems to have cured it. :? :? :?
Re: Bad Rattle Help ! by Drift on Thu Jun 19, 2008 10:28 pm
Again ball joints or dry suspension bushes, when I went through water like at Corwen my creaking stopped :wink:
Re: Bad Rattle Help ! by Sir-Doris on Fri Jun 20, 2008 12:11 am
Im going with the suspension bushes as I did all the ball joints top and bottom and both sides a month or two back. Funny though that the creak started after I washed the car, then it was bone dry for a couple of weeks and then it rained and its all gone.
Now that i think about it it is more of a squeeking then a creaking.
Re: Bad Rattle Help ! by Drift on Fri Jun 20, 2008 8:05 am
Silicone spray is your friend :D
