changing a belt tensioner...
changing a belt tensioner... by Wilberforce on Fri May 30, 2008 5:03 pm
wotcher folks..
been out fettling under the car today, after popping by my local auto parts place for a new aux belt tensioner. The old one, well, I'll post a piccie later - it's a mess, hehe...
anyhow, got the bash plate off, undone the bolts, etc etc, refitted new part which leaves just one question - how do you remove that bloomin' pin which holds the damn thing closed so you can fit it, get the belt over the roller, etc??
any suggestions?? preferrably not of the kind "best done before fitting" etc, hehe...
Re: changing a belt tensioner... by Wilberforce on Sat May 31, 2008 6:00 pm
*nudge*
Anybody, no???
Re: changing a belt tensioner... by Lipton on Sat May 31, 2008 8:01 pm
Does your tensioner look like this?
http://s207.photobucket.com/albums/bb31 ... CF0002.jpg
http://s207.photobucket.com/albums/bb31 ... CF0001.jpg
If so, in the second picture you will see a square socket behind the pulley. A socket set 't' bar will fit in it and you can take the tension out to remove the pin.
Hope this helps. (If it is not like this then I'm sorry I can not help you).
1998 TransGlobe 2.5 TDS LWB
I started out with nothin' and still got most of it left
Lipton
Re: changing a belt tensioner... by Wilberforce on Sun Jun 01, 2008 10:36 am
Sadly not :(
Cheers for the thought though Martin...
Jim
