Frontera Technical Support • View topic - Approach and depature angles
Approach and depature angles by Trugga on Wed May 28, 2008 9:10 pm
Having managed to raise the ride height of the Sport yesterday evening, with the exceptional help and enthusiasm of A friend, I decided to measure the approach and departure angles.
Front = 45º
Rear = 45º
Also, there is just about 24" of clearance under the rear most crossmember and the front winch roller fairlead clearance is also close to 24" clear.
Not bad I thought :D
Re: Approach and depature angles by Red Oktober on Wed May 28, 2008 9:13 pm
those are impressive numbers Lawrence 8) 8)
Re: Approach and depature angles by john (smifffy) on Wed May 28, 2008 9:15 pm
sounds good lawrence
any photo's to show??
Re: Approach and depature angles by Trugga on Wed May 28, 2008 9:16 pm
If the weather improves for tomorrow evening, I'll take a comparison photo with the BBB, nose to nose and rear to rear.
Re: Approach and depature angles by Road Hog on Wed May 28, 2008 9:17 pm
I just want to know if it went under the garage door. :shock: :shock: :D
Re: Approach and depature angles by Trugga on Wed May 28, 2008 9:23 pm
I got in a bit late this evening, so haven't yet tried it.
Also, I didn't want to accidentally knock the door of its runners gain - it'd be a bit awkward to fix it in the dark.
Maybe the weekend, when I can fettle with the garage door.
Re: Approach and depature angles by brachunky on Thu May 29, 2008 12:07 am
What is regarded as a "good" angle for non competitive off roading and, pray tell Lawrence :D , what method did you use to get your angles? :lol: :lol: (the trucks,not yours!)
3 inch suspension lift
31 10.5 Muds
Re: Approach and depature angles by Road Hog on Thu May 29, 2008 12:12 am
Re: Approach and depature angles by brachunky on Thu May 29, 2008 8:25 am
31 10.5 Muds
Re: Approach and depature angles by alex on Thu May 29, 2008 9:09 am
sohcahtoa :lol:
Re: Approach and depature angles by john boy on Fri May 30, 2008 8:18 pm
Does anyone kmow off the top of the head what is angle before a fronty rolls over on it's side while we are on about angles.
Re: Approach and depature angles by Drift on Fri May 30, 2008 8:30 pm
3 door hard top
Left side 40 degrees
Right side 44 degrees
5 door
left 44 degrees
Right 42 degrees
:wink:
Re: Approach and depature angles by Drift on Fri May 30, 2008 8:39 pm
Approch angles from stock
Without nudge bar all models 41 degrees
Departure angle without tow bar 3 door hard top and five door 29 degrees
Soft top 28 degrees
Ramp angle soft top and 3 door hard top 25 degrees LWB 22 Degrees
Re: Approach and depature angles by Trugga on Fri May 30, 2008 8:41 pm
Remember this photo:
well, here's an update:
I think I might have over done it :oops:
Re: Approach and depature angles by Red Oktober on Fri May 30, 2008 10:05 pm
looks like you've well and truly over done the torsion bars Lawrence :wink:
