Frontera Technical Support • View topic - more help required
more help required
more help required by perfectprincess on Fri May 23, 2008 6:51 pm
Hi guy and gals well i need more tech advise. Took my petrol 2.2 16v fronty to the garage they said prob was head gasket, ive now had that done and collected it today but! :( when i drive it the temp gauage shows 80 oc rad hoses are soft, when i turn of ignition the cooling fan cuts in and the rad hoses go rock hard, if i turn the ignition on the temp gauage reads 100oc+ any one got any ideas, all help appreciated
perfectprincess
Frontera Goddess
Frontera Goddess
Re: more help required by Road Hog on Fri May 23, 2008 7:02 pm
80 degrees normal running temp is a little high,have they used proper VX pink anti-freeze/inhibitor ? there is an issue using normal blue anti-freeze eating the oil cooler.
Ignition off then on again temp rise is normal.
Get the garage to check for air locks.
Re: more help required by john boy on Fri May 23, 2008 8:10 pm
Does sound like an air lock in the system is the heater hot as well?
Re: more help required by perfectprincess on Fri May 23, 2008 8:16 pm
gone to have a check love my fronty x2 but hate when they go wrong especially as its just cost me £541.00 to have the head gasket + service done :( :( :(
perfectprincess
Frontera Goddess
Frontera Goddess
Re: more help required by Silver Ghost on Fri May 23, 2008 8:35 pm
Silver Ghost
Registration Year: 1999/S
Re: more help required by perfectprincess on Fri May 23, 2008 9:42 pm
took it there because the hoses were hard and overheating. And yes the heater is hot :(
perfectprincess
Frontera Goddess
Frontera Goddess
Re: more help required by john boy on Fri May 23, 2008 10:11 pm
Are you sure the water pump hasn't got a spilt in the impellar and it's not doing anything. are all the hoses hot when its been run :?:
Re: more help required by perfectprincess on Sat May 24, 2008 2:26 pm
yes the hoses are hot. when the engine is running the hoses are soft, when you turn it of the hoses go rock hard and very hot and then the cooling fans then cut in straight away :(
perfectprincess
Frontera Goddess
Frontera Goddess
Re: more help required by john boy on Sat May 24, 2008 4:31 pm
Defo an air lock some where in the system. leave it running with coolant tank cap off and see if any air comes out, or if it bleeds its self. but if you have paid for a job to be done then they should sort it out for you. was this the fault on it in the first place?
Re: more help required by perfectprincess on Sat May 24, 2008 4:38 pm
yes it was but when they took the head of the head gasket had blown inbetween 3 and 4.
perfectprincess
Frontera Goddess
Frontera Goddess
Re: more help required by john boy on Sat May 24, 2008 6:38 pm
Was the cylnder head skimmed when the job was done?
Re: more help required by perfectprincess on Sun May 25, 2008 6:11 pm
John M
yes the head was skimmed and a head saver was fitted.
perfectprincess
Frontera Goddess
Frontera Goddess
Re: more help required by john boy on Sun May 25, 2008 8:48 pm
I take that the thermostat has been checked to see if opens or is not stuck.
Re: more help required by Road Hog on Sun May 25, 2008 10:26 pm
Who did the head skim ?
Re: more help required by perfectprincess on Mon May 26, 2008 3:33 pm
a local company that the garage sent it to
perfectprincess
Frontera Goddess
Frontera Goddess
