Frontera Technical Support • View topic - Wheel Spacer Post...Cant find it??
Wheel Spacer Post...Cant find it?? by Rick on Wed May 21, 2008 8:23 pm
Hi all,
I cant seem to find the discussion page on wheel spacers for some reason? Probably been a long day!! Can someone point me in the right direction please!!
Rick
2001 Discovery ES TD5 (EGR Bypass, De CAT, General Grabber AT2 Rubber)
2000 Fronty SWB RS 2.2 Petrol (LSD Model)......RIP
Insa Turbo Sahara Boots
Maycom EM-27 CB
SS100HF Safari Snorkel
3" Lift (LA Supertrux)
200BHP MGF and '04 MGZR 160
Rick
Modifications: 3" Lift, Safari Snorkel, CB, Insa Turbo Sahara M/T's
Re: Wheel Spacer Post...Cant find it?? by dandan on Wed May 21, 2008 8:34 pm
I'm looking but all the links I've found go to the old site :x
dandan
Re: Wheel Spacer Post...Cant find it?? by Road Hog on Wed May 21, 2008 8:37 pm
Re: Wheel Spacer Post...Cant find it?? by dandan on Wed May 21, 2008 8:46 pm
See below Red has sorted it....A friend
dandan
Re: Wheel Spacer Post...Cant find it?? by Red Oktober on Wed May 21, 2008 8:47 pm
Re: Wheel Spacer Post...Cant find it?? by Drift on Wed May 21, 2008 8:49 pm
Old site again, one of the glitches since we had the problems :roll:
Re: Wheel Spacer Post...Cant find it?? by Rick on Wed May 21, 2008 10:45 pm
Cheers Lads!!
Maycom EM-27 CB
Rick
Re: Wheel Spacer Post...Cant find it?? by Rick on Wed May 21, 2008 10:46 pm
The link isn't workin, it goes t a list of suppliers??!!
Maycom EM-27 CB
Rick
Re: Wheel Spacer Post...Cant find it?? by Drift on Wed May 21, 2008 10:48 pm
Yer tis a problem still needs resolving from the site change over
Re: Wheel Spacer Post...Cant find it?? by Rick on Wed May 21, 2008 10:51 pm
Can anyone just give me the pro's and cons quickly in this post??
Worth doing or not??
Rick
Maycom EM-27 CB
Rick
Re: Wheel Spacer Post...Cant find it?? by Red Oktober on Wed May 21, 2008 10:55 pm
to be honest ..........personally i'd be rather fit wider wheels than use spacers
Re: Wheel Spacer Post...Cant find it?? by Drift on Wed May 21, 2008 10:57 pm
Ive thought a lot about them, personally I would go with a bigger offset wheel, not as much stress on the axels and drive train, though for a total offroader I wouldnt see any problems with them, but again the cost of good spacers to the cost of a set of steel wheels can be the same.
I got this just from bigger offset wheels
There have been issues with failing wheel studs and stub axels but they could be low quality spacers and studs, but my money would always be on the wheels, you pays ya money you makes your choice.
Re: Wheel Spacer Post...Cant find it?? by Road Hog on Thu May 22, 2008 1:10 am
I see you are in a B series,I am running 31x10.5x15 on A series alloys & due to offset have a 75mm a side increase in track width.
Star Wheels or PepperPots will give the increase,if this is what you are looking for say so & I will post piccys.
Wheel change is the real answer but if you want/need to use spacers check out LA supertrucks they have billet type.
Re: Wheel Spacer Post...Cant find it?? by Rick on Sat May 31, 2008 8:54 pm
Hi mate can you post some picss for me please??!!
Maycom EM-27 CB
Rick
Re: Wheel Spacer Post...Cant find it?? by Drift on Sat May 31, 2008 8:58 pm
If Im not mistaken these will give the desired effect, though I stand to be corrected :wink:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=016
