This Doris is now right royally miffed!
This Doris is now right royally miffed! by Sir-Doris on Wed May 21, 2008 11:55 am
You know how it is, you go outside to check summat on the car. In this case clean up around the all the calipers. Took the wheels off and had a look at the brake pads and by golly green stuff (or lack of) Batman. My EBC 7000 Greenstuff pads have worn away to nothing already. I only put them on before we went to Betys Y Coed for the weekend. So they lasted a sum total of what? 2 months or thereabouts. Surely this cant be right? £68.00 they cost for the front and rear. Iv had Halfords pads that last longer! Luckily I kept my old pads as they werent that worn anyway and Iv put them back on. I only wanted the EBC pads to go with the braided brake lines in the hope I would get some serious stopping power. While they did work reasonably well on the car I dont think they were worth the premium.
Then while I was poking around the front end I have worked out that I have properly blown the front diff. There is a big hole in the bottom of the diff casing and it looks like it was caused by something inside bursting outwards. Although the lack of grinding noise is baffling me. So Im figuring it will be easier and cheaper in the long run to source a 2nd hand diff from somewhere.
And while poking about at the back end I have a weeping rear diff cover from where a rock or some such has pulled the lip away from the diff casing. Iv tightened up all the bolts and hammered the lip flat against the diff cover again. Il have to keep an eye on it and if it keeps weeping Il take it off and check it properly and see if I need a new cover or just a reseal.
Also got round to checking the Prop shaft bearing and I definately need a new one. Plenty of play in it when wiggling the propshaft from side to side.
Its all a big pain in the bum and I wish christmas would come early now.
Once my teeth had come apart in my front diff it stopped making a noise
2.8TD SWB in ASBO Green
1996 Sport S 31-10.5-16 Machos fitted
Hi-Lift Jack/Waffle Boards and Asbo Rack !
Its not the size of your engine....its how you use it that counts !
NiftyWolfie
Modifications: HD Trooper Springs, Cibbie Spot Lights, Asbo Rack, CB, Split Charge System, Roof lights, Waffle Boards.
Re: This Doris is now right royally miffed! by Drift on Wed May 21, 2008 1:34 pm
:shock: Bugger :shock: the rear diff will need resealing, once they go htey go no stopping them, but easy to do and not to lomg a job.
There should be a bit of play in the rear prop no more than 1cm from memory.
Front diff as you say replacement :(
Re: This Doris is now right royally miffed! by jjcymru on Wed May 21, 2008 2:02 pm
ive a front axle here you can have for a tenner, otherwise its scrap.
jjcymru
Re: This Doris is now right royally miffed! by Drift on Wed May 21, 2008 2:30 pm
Are they the same ratio's JJ ?
all the fronties have different ratio diffs. unfortunately the only way to get one from a different engined fronty would be to replace both the front and rear from a donor car. But if its a 2.2 Il take it.
if your engine code is a X22XE ...your axle ratio is:- 4.88:1
Re: This Doris is now right royally miffed! by alex on Thu May 22, 2008 6:27 pm
Bummer Phil, Front diffs are a pain, but doable. At least with flipped ball joints fetching the cv joints out is a quicky, then its the 4 bolts around the hangers and the big 4 that hold them in. Worth stipulating when searching that you want the half shafts too, may have stripped some teeth.
Re: This Doris is now right royally miffed! by Sir-Doris on Wed May 28, 2008 10:35 pm
Rear is holding up ok for the moment. Havent really looked anywhere for a new diff yet. other expenses to get outta the way first. Hope everyone had fun at Kirton.
