Frontera Technical Support • View topic - loss of power
loss of power
loss of power by terry (the fish ponds) on Mon May 19, 2008 5:38 pm
hi all did any body have any ideas on the loss of power to my 2.5 td 98 "it runs ok but it has not got any power its like its got feul starvation
all filters and oil just been changed but no better
could it be the turbo :?: :?: :?: :?:
it was running fine one minute then went to put foot down up a hill an no power
all the best
terry
terry mair
Re: loss of power by Road Hog on Mon May 19, 2008 8:09 pm
Do you mean will not rev or will rev but not pull ??
Re: loss of power by gregster on Mon May 19, 2008 8:17 pm
Re: loss of power by terry (the fish ponds) on Tue May 20, 2008 8:45 am
yes it will rev fine standing still but try pulling away to over take etc it will not respond
under own steam it will still get up to top speed :?: :?: :?:
terry mair
Re: loss of power by Road Hog on Tue May 20, 2008 9:18 am
That does sound turbo related,
1) Check turbo & intercooler hoses for damage (splits,loose connections,etc).
2) Check for turbo rotation...remove turbo to intercooler hose,(with fingers well clear,get an assistant to gently & progressively rev the engine),assuming rotation next with engine off & keys removed chech turbo for end float & side play.
3)Remove the intercooler hose at the manifold (get your assistant back to repeat above)with your hanh over the open hose air pressure should increase with revs,if not & the above check is OK this would indicate a blocked intercooler.
Re: loss of power by Mossey on Tue May 20, 2008 12:00 pm
sounds to me like you could have a split fuel hose or air still in fuel system somewhere.
The 2.8 is renowned for fuel lines splitting where they come out of chasis up to tank, dont know if 2.5 is same
Mossey
Re: loss of power by terry (the fish ponds) on Tue May 20, 2008 12:21 pm
cheers for the replys i will check them out and post the results once again thanks :) :) :)
terry mair
Re: loss of power by Road Hog on Tue May 20, 2008 1:02 pm
Also keep an eye on the colour & amount of exhaust smoke & when/if it occurs.
Re: loss of power by terry (the fish ponds) on Wed May 21, 2008 7:16 am
no smoke from exhaust at all :?: :?: :?:
terry mair
