Whats the Fix for This Leak
Whats the Fix for This Leak by country_Est on Mon May 19, 2008 2:10 pm
Hi Guys
I have a leak which seems to be from the Power Steering system. What I would like to know is does anybody have an idea to what the problem is and what the fix might be, and possible costs.
Trev
2000 Frontera 2.2 DTi Ltd
country_Est
Vehicle Name: panserbjørne
Re: Whats the Fix for This Leak by Red Oktober on Mon May 19, 2008 4:04 pm
are you sure it's a power steering fluid leak ......
you went laning the other day didn't you ......and got stuck.....
Re: Whats the Fix for This Leak by country_Est on Mon May 19, 2008 8:24 pm
Carl,
The stuck was grounded on Tank and axel, pulled off backwards so nowhere near the bits up front that are covered by the metal body armour I have fitted.
The leak has just started and the Laning was 2 weeks ago, (just slow with the pics :D ). When laning the missus was away so was using her parking spot and no leaks on that side of the drive, now its stating to show up on "my" side of the drive, and the leak is comming from the (techincal bit comming here :roll: :roll: ) bit that moves when the steering wheel is rocked :dance: .
Just wondering if its possible a seal and can be fixed with the Power steering sealant stuff, or whether I am looking a a few hundred for a new rack :?:
country_Est
Re: Whats the Fix for This Leak by Drift on Mon May 19, 2008 8:56 pm
I would try the sealant additive first and quick, it might work if the seal isnt to far gone.
Re: Whats the Fix for This Leak by bartman on Fri May 30, 2008 6:27 pm
hi there is a place called transhock distribution in brum that will recon :) your unit for about 120 quid
bartman
