NNNgGG Ball joints...
NNNgGG Ball joints... by alex on Sun May 18, 2008 4:21 pm
Just need a little rant.....
Have surgicaly removed the lower ball joint all but the shaft. Have destroyed a lgv scissor ball joint remover (went bang), have heated it till it glows, chilled it and drowned it wd40. Have beaten it with hammer (helped mood) but all to no avail.
So its being left to soak longer while I contemplate a better way of extruding the bugger.
Needless to say I dont really intend on trying the drivers lower before kirton.
Oh and my driver cv boot is split, c'est dung.
Re: NNNgGG Ball joints... by Drift on Sun May 18, 2008 4:36 pm
Welcome to mine and Tims world this time last week, about this time the thunder storm started and we where outside :roll: took about 3 hours each side and a welded bearing collor on to the shaft :evil:
All I can say is keep belting it like mad, we did the lowers last week.
Re: NNNgGG Ball joints... by nitromotor on Sun May 18, 2008 4:36 pm
I know how you feel, :evil: I don’t get on with bottom ball joints, one job I never ever have any luck with… :|
Best thing I can recommend is to unwind the torsion bar, undo the BJ castle nut but leave on the last 3 threads or so to prevent damage.
Insert splitter, wind the splitter up, heat the casting/hub carrier, then whack the stuffing out of the hub carrier.
:idea: Another way is to put a bottle jack under the BJ and jack up, then hit the hub carrier.
(just make sure you have supports/ stands under the car) :wink:
Re: NNNgGG Ball joints... by weave67 on Sun May 18, 2008 4:43 pm
yep thats what i did slacken the torsion bars all the way off ,then out with the "ommer" :twisted:
Re: NNNgGG Ball joints... by Drift on Sun May 18, 2008 5:22 pm
We vitually took the hub off, had the jack under the post, heat and artic spay... nothing,... ball joint splitter.. broke it .. then with the bj splitter broken bit hammered the bjesus out of the thing till it went, it was painfull and soul destroying :evil: but got there :D
Re: NNNgGG Ball joints... by alex on Sun May 18, 2008 6:43 pm
hhhmmm
I'm only left with the shaft.... cant get nut back on either. looks like beating is the best option.
Re: NNNgGG Ball joints... by Drift on Sun May 18, 2008 6:47 pm
We even had a go at grinding one of mine, no return then either, never made any difference :roll:
Re: NNNgGG Ball joints... by nitromotor on Sun May 18, 2008 6:56 pm
Get the jack under it to put the weight of the front end on the bleater, then whack the stuffing out of it… :lol:
Re: NNNgGG Ball joints... by Red Oktober on Sun May 18, 2008 6:57 pm
mine came off easy ......i just undid the torsion bar to realease all the preasure ....undid the bj nut (but didn't take it off) ...then hit it a few times and it came away quite easy
and that was both sides done and complete in under an hour 8) 8) 8) 8)
Re: NNNgGG Ball joints... by nitromotor on Sun May 18, 2008 6:58 pm
:roll: There is always someone with all the luck :lol: :lol: :lol:
Re: NNNgGG Ball joints... by Red Oktober on Sun May 18, 2008 7:02 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Re: NNNgGG Ball joints... by alex on Mon May 19, 2008 7:22 pm
:party: I got one front wheel on my truck, thanks to 2 bits of 30mm thick 60mm wide 150mm long bits of steel and 2 long 16mm bolts. The add hock press didnt work on its own, needed some serious heat and one big hit from the ommer.
2nd side now has hub off, new top ball, just need the cv boot (bought glue together jobbie), new bearings (on route from Milners, no inner listed so gone for trooper) and the dreaded ball joint. Will attack with grinder Tuesday, having quickly done the jack and T... then the propper splitter to no avail.
Re: NNNgGG Ball joints... by brachunky on Mon May 19, 2008 7:31 pm
Just make sure you grease up the new bj with coppaslip before tightening it up :wink: This makes a huge difference when having to separate them again :D
3 inch suspension lift
31 10.5 Muds
Re: NNNgGG Ball joints... by Sir-Doris on Mon May 19, 2008 8:08 pm
Acres of trouble with my bottom BJ's. Broke a fork type splitter per side trying to get them off. Then as mentioned I copper greased them before putting the new ones in. All tight and steady on the road now though so well worth it.
Re: NNNgGG Ball joints... by alex on Tue May 20, 2008 6:10 pm
YYYYYYEEEEEEE
Tis done, last one was a swine, but MR.Hammer teamed up with the home made press. Just waiting to finish the cv joint an its wheels back on. :dance: :dance: :dance:
Honestly, sometime these motors are a pig to work on, the wife is less work :axe:
