Strange running
Strange running by woodwizzard on Thu May 15, 2008 7:23 pm
Not got a monty section so will stick it here. Over the last week or so the 3.2 monty has been a little erratic at tick over, starts fine hot or cold and runs better cold. When warm has a slight flat spot around 2K rpm and on tick over there is a lumpy burble from the exhaust. Today it cut out 3 times at stand still and when re-started the revs rose and fell between 1 to 2.5k rpm. It ran ok for 14 miles but was still reving on its own when I pulled into a garage. After leaving the garage it ticked over as normal. A couple of times when I pull off the car just feels like it is out of fuel and as you lift off the pedal it picks up again. When I took the dogs out tonight it tick over at 2k rpm and after being stopped it then was fine. I'm guessing its a sensor but any ideas welcomed.
Re: Strange running by Drift on Thu May 15, 2008 7:51 pm
Had that with an escort a long while ago, turned out to be the MAF.
Re: Strange running by woodwizzard on Thu May 15, 2008 8:13 pm
Do you know where that is on the 3.2?
Re: Strange running by Drift on Thu May 15, 2008 8:18 pm
Soz no :oops: , but try looking through the frontera V6 3.2 might be in there :wink:
Re: Strange running by woodwizzard on Thu May 15, 2008 8:23 pm
Cheers Ste, just found a pic and test for the sensor in the chilton manual, but is now a bit dark outside so will have to wait till the morow. Have to play juggler instead :lol:
Re: Strange running by Drift on Thu May 15, 2008 8:30 pm
Great stuff :D they can be cleaned but be careful :wink:
Re: Strange running by Road Hog on Thu May 15, 2008 9:31 pm
Also check the lamda sensors,one each side ahead of catalytic coverter
Re: Strange running by woodwizzard on Thu May 15, 2008 9:39 pm
Only got one on the monty and had that changed for mot so hoping that is ok. It was the reason for failing the test and once replaced it passed.
Re: Strange running by alex on Thu May 15, 2008 10:34 pm
Maf is after the air box, a removeable bit with the sensor wire.
If it suffers the same intake manifold problem as the 3.2 could be worth spraying some carb cleaner or wd40 around the joint from the common air chamber to the intake manifold to see if it changes note of the engine running. If so I cured mine with some exhaust putty, if its in the inside of the V its a new gasket, not a fortune.
Re: Strange running by woodwizzard on Fri May 16, 2008 6:19 pm
Well what I thought was the maf was the iac instead. It was black and filthy so gave it a clean and the erratic running has not appeared today so that must have cured that, but the lumpy burble and slight flat spot is still there, could this still be the maf? On the monty there is the hose that runs from the airbox to the throttle body but there is nothing between it that looks like a maf. The chilton book shows a picture of the maf on its own but not where it is, will have to have another nose around.
Re: Strange running by woodwizzard on Tue May 20, 2008 8:40 pm
Can't find maf anywhere, there is no sensor between airbox and throttle body, is the fronty v6 a similar layout and is there a piccy on the site of one?
Re: Strange running by Red Oktober on Tue May 20, 2008 8:41 pm
Jim ........................ have you asked them on itock :wink:
Re: Strange running by woodwizzard on Tue May 20, 2008 8:51 pm
Good thinking that man. It shows piccy of one in manual but I can't find it anywhere(assuming it has one) :?
Re: Strange running by woodwizzard on Mon May 26, 2008 7:18 pm
PANTS! Funny running has returned, tickover is either 2k rpm or it slowly drops and then dies. Have tested tps, map, cleaned and tested iac and all are ok. There seems not to be a maf so can't check that, did ask on itoc and the guys there posted an engine pick, looks same as mine, no maf. When putting foot down there is just a big hole, ease off then floor it and it flips round to the redline fine. Thought it could be blocked exhaust or cat but would that be intermitant?? Had decided to keep and use for work but if it keeps naffing me around I will get somthing else. HELP...please.
Re: Strange running by Drift on Mon May 26, 2008 7:20 pm
Is the intake manifold leaking ?
Re: Strange running by woodwizzard on Mon May 26, 2008 7:30 pm
Not sure, not done the wd40 check, it could be, it tends to run better cold and rougher when warm so maybe the seal is looser when warm??
Re: Strange running by Drift on Mon May 26, 2008 7:32 pm
I would think it would expand when warm, but possibley more pressure when the engine is up to speed, cant hurt to check though :D
Re: Strange running by woodwizzard on Mon May 26, 2008 7:36 pm
At this rate it is fast heading towards becoming an offroad toy :twisted: :twisted: Tax runs out end of june so it has until then to start behaving or it will have a date with mr.grinder.
Re: Strange running by Drift on Mon May 26, 2008 7:37 pm
There is a stunning MU on ebay at the mo :wink:
Re: Strange running by woodwizzard on Mon May 26, 2008 7:43 pm
Is it the one in Norwich or is there another one on, have to have an ebay browse in a mo. The one in Norwich is a 3.1, yum.
