Frontera Technical Support • View topic - Painting is hard!
Painting is hard!
Painting is hard! by bigscarydeathfish on Thu May 15, 2008 8:45 am
I have completley buggered up the painting!
When I sanded down the rust spots I put masking tape around the area and then put 3 coats of primer on. Problem was that the coats were way to thick and now there is a ridge between the new primer and existing paintwork.
Arse!
Suppose I will just have to keep sanding until I get a smooth finish.
On the plus side though, I am picking up a hard top and new drivers seat on Saturday. Something else for me to balls up on Sunday.
bigscarydeathfish
Modifications: Converted from soft to hard top. 2" shackle lift. Mud tyres on their way!
Re: Painting is hard! by Red Oktober on Thu May 15, 2008 8:51 am
primer is only meant as an undercoat ....it's the colour that is built up over a few layers (thin coats over a few layers will get you the best end results) :wink:
Re: Painting is hard! by bigscarydeathfish on Thu May 15, 2008 9:47 am
Thanks Red,
Will try that.
Should I mask around the area to be painted or just freehand?
What about using a palm sander? The areas are reasonably large and it would speed things up a bit and give a more even finish?
bigscarydeathfish
Re: Painting is hard! by huggy on Thu May 15, 2008 9:52 am
mask it off but each time you rub down and add another coat move the masking tape back a bit,this way you dont get a ridge :wink:
huggy
Re: Painting is hard! by jellybaby on Thu May 15, 2008 12:18 pm
good luck i'm just doing my bonnet and the top of the wings just take your time drink plenty of tea. if you didn't get it wrong sometime you wouldn't be human looks like i'll be rubbing my bonnet down to do again ah well thank god for nice weather and an understanding wife.
dave
Re: Painting is hard! by Alchamist on Thu May 15, 2008 12:29 pm
You have no idea how tempted I am to repaint my whole truck ... :lol:
Not sure the neighbours would appreciate me out there with an airgun though ...
Jay
Alchamist
Modifications: .
* CB
* Rear recovery shackles
Re: Painting is hard! by Red Oktober on Thu May 15, 2008 12:54 pm
Re: Painting is hard! by bigscarydeathfish on Thu May 15, 2008 1:33 pm
If I park mine next to your we could get a 2 4 1 deal!
bigscarydeathfish
Re: Painting is hard! by Alchamist on Thu May 15, 2008 5:29 pm
Jay
Alchamist
Modifications: .
* CB
Re: Painting is hard! by gregster on Thu May 15, 2008 10:16 pm
Hiya,
Dont hard edge mask your primer if you dont want a build up. Best now to block it back so still covers your filled/rusted areas but taking the bulk of the orig paintwork. Then flat out/key all your paintwork p600 if doing base and clear or 400 if doing 2k.This should then cover ok.
Then panel wipe down to get rid of any silicons and tack cloth off to get rid of any dust particles on the surface.
Dont hard edge mask anything where you dont want a visable edge in the paint. Useful trick is to use 2" masking tape, roll it over backwards on itself so it makes a long tube with the sticky on the outside. Use this to mask in your shuts etc where you dont want a hard edge by gently sticking in around the shut. do not squash it down-it needs to retain its cylindrical shape to allow to paint to drift under, therefore not leaving pronounced lines where your painting finishes.
If not painting original colour it is worth remembering that dark colours tend to show any infections in your prep than light colours. Also bear in mind that whites and reds are particularily prone to fading unless base and clear and will more difficult to match should you need to repaint anything at a later date. Just look at white or red cars under streetlights or petrol station lighting and you will immediately spot if any panels have been repainted.
Hope this helps and good luck
Gregster
Re: Painting is hard! by bigscarydeathfish on Fri May 16, 2008 9:07 am
Thanks for that gregster.
I bought myself an electric detail sander last night and set to work sanding down the ridges I had made. It went very well and I am quote pleased with the result so far.
I will prime again tonight, taking on board all the tips, and hopefully get a first coat of colour on by Sunday.
Will put some piccys of the various stages on soon.
Cheers chaps.
bigscarydeathfish
Re: Painting is hard! by madchef on Fri May 16, 2008 10:02 am
Andi
Rising out of Bedlam and into my own mad world! #@~#
SWB called Arfur Grunt
madchef
my other jobs the GWR Liaison Officer
Model: 2.5 TDS Sport 3dr
Vehicle Name: Arfur Grunt
Re: Painting is hard! by bigscarydeathfish on Fri May 16, 2008 10:26 am
bigscarydeathfish
Re: Painting is hard! by madchef on Fri May 16, 2008 10:51 am
One of our neighbours down the road did that shot its' tail feathers off.Did knock it out of the tree the other day.Got my own back.Fell 20 foot but just about managed to find its feet :twisted: :evil:
Andi
madchef
Re: Painting is hard! by bigscarydeathfish on Fri May 16, 2008 11:17 am
Roast peacock! mmmmmmmmmmmmmmm
bigscarydeathfish
Re: Painting is hard! by Red Oktober on Fri May 16, 2008 11:28 am
pmsl :lol: :lol:
Re: Painting is hard! by Annamarie Oktober on Fri May 16, 2008 11:43 am
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
Annamarie Oktober
Re: Painting is hard! by madchef on Fri May 16, 2008 2:07 pm
Andi
madchef
Re: Painting is hard! by bigscarydeathfish on Sun May 18, 2008 6:38 pm
decide to sand off all the primer and start again!
got a great finish with the detail sander and have put two coats of primer on, no hard edges so far!
will give her a sand off tomorrow and apply some colour.
any news on that peacock pate' yet?
bigscarydeathfish
Re: Painting is hard! by madchef on Sun May 18, 2008 8:08 pm
:twisted: :evil:
Better than pate!!!Mate has high power pressure hose in my yard.Blast his little feathers off.Watch out It's coming! :twisted: :evil:
Andi
madchef
