HELP!!!! NEED A CLUCH KIT!!
HELP!!!! NEED A CLUCH KIT!! by melvin666 on Fri May 09, 2008 10:23 pm
hi anyone out there know where i can get a cheap cluch kit for my 2.2 p reg petrol frontera as mine is on its way out pref a company that will post or deliver
melvin666
Modifications: chrome bull bars ,big all terrain tyres, 4x 4"angel eye spots on roof, rear light gaurds,home made snorkel, just fitted 2"lift and a 2" body lift
Re: HELP!!!! NEED A CLUCH KIT!! by andysd1 on Fri May 09, 2008 10:43 pm
Its not the clutch ya!!!!! by melvin666 on Fri May 16, 2008 6:31 pm
it not the cluch just saved £150+ fitting for a clutch when the bulk head is cracked so when you push pedal the bulk head moves and not the clutch having plate welded over it on thursday going to be a nightmare striping it all out to get a good strong plate in there and weld
melvin666
Re: HELP!!!! NEED A CLUCH KIT!! by Fod on Sat May 31, 2008 9:04 am
How did you get on melv?
Got exactly same problem on my 2.8 :? gears been a bit 'crunchy' for a few weeks now, but in the time-honoured fashion I've ignored it, until I got a frantic call from mrs. FOD saying she couldn't get it in reverse in Tesco's carpark, and every time she tried it was inching closer and closer to an expensive looking silver car parked right in front of her ("You know, one of them German one's" she said)
It's not the bulkhead itself, but the mickey mouse plate that VX decided to tack weld to the bulkhead, then bolt the pedal box to (why they couldn't have put the bolts right through the bulkhead, like they did the brake pedal mounts, gawd only knows??!?)
Hope you've got yours sorted (anyone else had this problem? Anyone got a simple solution? :? )
Regards, FOD
'95 Frontera 2.8 TD Sport S (because I'm worth it!)
Fod
Re: HELP!!!! NEED A CLUCH KIT!! by Drift on Sat May 31, 2008 9:31 am
Hi Fod, check here
viewtopic.php?f=3&t=5332
