Frontera Technical Support • View topic - Fog Lights Wiring
Fog Lights Wiring
Fog Lights Wiring by aadams1x on Wed May 07, 2008 11:16 pm
Hi...
I have recently put a bull bar with 4 fog lights onto my Frontera Sport 1998. I was pleased to find the connectors infront of the radiator and hooked them all up but no fog lights. I then realsied I needed to buy the switch for the pod where the lights are located. I have now done this, connected the blocks together and the rear ones work still but nothing from the fronts. The light on the switch is lighting up when they should be on so I know there is power...
Is there anything else I have not done...? Thanks from a guy in need of help!
aadams1x
Re: Fog Lights Wiring by Red Oktober on Wed May 07, 2008 11:28 pm
Is the relay in the "under bonnet" fuse box
Re: Fog Lights Wiring by Road Hog on Wed May 07, 2008 11:37 pm
Re: Fog Lights Wiring by roiphil on Thu May 08, 2008 12:47 pm
Hi
I am considering a set of front fog lights aswell, i have a 94 Series A Sport, what colour is the connection block infront of the radiator and where does the relay go in the fuse box under the bonnet, a pic would be helpfull if possible, also any other fuses, i have a front foglight switch for inside to connect, what colour is that connection block, thanks for any advise in advance
Phil
In Southern Ireland
94 Frontera Sport 2.0I
I can see the mountains so its going to rain !
i cant see the mountains so its raining !
roiphil
Registration Year: 1994/M
Vehicle Name: Jeep
Modifications: Southern Ireland
Southern Ireland number plates
Immobiliser immobilised as it was a pain in the 4rse
Converted to commercial
Wrap around bullbar, driving lights and fog lights
Roof Bar Lights
(come at me with your full beams boy racers and you get an eyefull of 10 lights)
Rear light guards bumper and body ones
LWB Rear Body Lights
Rock Sliders
(I like my allround protection)
255/75 R15 Kumho
Pajero Seats
38mm Wheel Spacers
2 inch suspension lift
Region: Northern Ireland
Re: Fog Lights Wiring by Red Oktober on Thu May 08, 2008 12:56 pm
Fog lights plug into the black connector ........spot lights plug into the blue connector....
the "in-cab" block should be blue ...and on the right hand side of the steering wheel (unless your wheel is on the wrong side)
Re: Fog Lights Wiring by 4x4 bobby on Thu May 08, 2008 2:14 pm
Re: Fog Lights Wiring by roiphil on Sun May 11, 2008 3:14 pm
Thanks for all replies, where does the relay go in the under bonnet fusebox and what is it s serial number, if anyones got a pic that would be great, i have a series A 94 Sport, thanks phil
In Southern Ireland
roiphil
Vehicle Name: Jeep
Roof Bar Lights
Rock Sliders
255/75 R15 Kumho
Pajero Seats
38mm Wheel Spacers
