Frontera Technical Support • View topic - can any one help?
can any one help?
can any one help? by perfectprincess on Sun May 04, 2008 7:45 pm
Only just fixed one fronty thanks to all for help with that but know my fronty sport has a problem.
Ive got a 2.2 16 valve swb petrol 2001 ive noticed the water going down in the radiator it seems to be running above temp, the water disapears but no visual signs of water leakes, the cooling fan is working, ive tried filling the expansion bottle to the very top but the rad will not suck the water back into it to fill it back up. Can anyone shed any light on this prob for me hope so!
Thanks all
perfectprincess
Frontera Goddess
Frontera Goddess
Re: can any one help? by Drift on Sun May 04, 2008 7:52 pm
Is the rad bottle emptying ?
and when you say above temp does it go into the red on the dash gauge ?
Re: can any one help? by alex on Sun May 04, 2008 7:56 pm
Is the water in the bottle milky? can you check the oil level and colour? Can you check the passenger front footwell, right up against the engine bay to see if the carpets are wet or discoloured?
Re: can any one help? by perfectprincess on Sun May 04, 2008 8:00 pm
perfectprincess
Frontera Goddess
Frontera Goddess
Re: can any one help? by brachunky on Sun May 04, 2008 8:03 pm
Open the oil cap and look at the cap.Is it a creamy colour at all?
3 inch suspension lift
31 10.5 Muds
Re: can any one help? by perfectprincess on Sun May 04, 2008 8:17 pm
perfectprincess
Frontera Goddess
Frontera Goddess
Re: can any one help? by alex on Sun May 04, 2008 8:17 pm
When the car is warm and running get someone to massage all the pipes to and from the rad, expansion tank, to and from the bulkhead for the internal heater, any water hoses you can trace to see if there is a corresponding movement in the expansion tank (hard to describe but the level should surge slightly as you squeeze its pipes ) Also check the drive belt on the from that turns the water pump to make sure its on and tight and turning the pump.
Re: can any one help? by perfectprincess on Sun May 04, 2008 8:22 pm
thanks Alex will give it a go supposed to be driving to london tues for work but must admit slightly worried to do so
perfectprincess
Frontera Goddess
Frontera Goddess
Re: can any one help? by Fronty81 on Sun May 04, 2008 8:36 pm
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: can any one help? by perfectprincess on Sun May 04, 2008 8:43 pm
matt
many thanks again will have a look tomorrow in the light. will let you know
perfectprincess
Frontera Goddess
Frontera Goddess
Re: can any one help? by alex on Sun May 04, 2008 8:53 pm
Good luck.
Re: can any one help? by fahl on Sun May 04, 2008 9:32 pm
Have you checked the thermostat
fahl
Location: London/Essex border U.K.About 5miles from Arena
Modifications: None>>>>>>Yet!!!
Re: can any one help? by Rifleman on Sun May 04, 2008 9:46 pm
This sounds to me as if it could be one of two possibilities.
If there are no visible leaks, then your engine is using the coolant rather than chucking it out.
This is usually caused by either a blown head gasket, or a blown inlet manifold gasket.
What happens is, in the case of the head gasket, it blows across from one of the water jacket holes to one of the cylinders. The coolant is forced under pressure across the break into the cylinder and it is forced out the exhaust. Rev the engine and see if you can detect any white smoke. this is a sure sign of this problem.
The inlet manifold gasket can give a similar sign if the same thing happens here. The gasket blows from the water jacket into the inlet port of one of the cylinders.
I hope this is not the case, but I hope this helps with sussing it out.
Keith.
Re: can any one help? by alex on Sun May 04, 2008 9:52 pm
If it does look like the head, have someone hold their hand in the path of exhaust gasses and rev to see if they get a damp hand.
Re: can any one help? by perfectprincess on Mon May 05, 2008 7:01 pm
thanks all for your suggestions i will give them all a blast it is bound to be one or the other. can you only buy replacement key remotes from vauxhall? or is there anywhere else i could go, having a run of bad luck with the frontys this week!!!!!!! :(
perfectprincess
Frontera Goddess
Frontera Goddess
