Frontera Technical Support • View topic - spring relocation guide Mk1
spring relocation guide Mk1 by alex on Sat May 03, 2008 6:54 pm
Its not a cone so its a guide I spose, but heres Mk1.
The components on right, item on left.
Close up.
The spare spear tip shape item will be cut in two and welded along side the one in the assembly to give a better reloctaion from any angle. I have knocked this one apart as the center ring isnt out of thick enough material, I mustve been day dreaming it wants to be out of 40mm really not 15mm to give the spring a good amount of wall to sit in after I put some rubber on the second disc.
I confess Ive not actually had the spring out of the Beast while planning so there will be some fettling when it comes to fit, will also be a weld in jobby as even with a body lift there aint room for long bolts to come through the hole in the chassis mount.
If anyone can see obvious pitfalls, constructive critisism is more than welcome.
Re: spring relocation guide Mk1 by Red Oktober on Sat May 03, 2008 7:05 pm
Looks ok ..from what i can see ..
maybe have a deeper wall on the inner circle bit
Re: spring relocation guide Mk1 by alex on Sat May 03, 2008 7:08 pm
Thats the bit that will go from 15mm to 40mm :wink:
Re: spring relocation guide Mk1 by Red Oktober on Sat May 03, 2008 7:11 pm
Re: spring relocation guide Mk1 by weave67 on Sun May 04, 2008 5:33 am
nice one alex,all built for a total cost of :roll:
Re: spring relocation guide Mk1 by Drift on Sun May 04, 2008 9:35 am
They look heavy but will certainly do the job, nice one fella :D
Re: spring relocation guide Mk1 by alex on Sun May 04, 2008 10:20 am
So far total cost is ................ naf all.
Its not what I would call heavy, made up of doughnuts rather than solid so turned over theres big holes underneath. Be3sides, do I look weight concious????
Re: spring relocation guide Mk1 by Drift on Sun May 04, 2008 11:21 am
Re: spring relocation guide Mk1 by Red Oktober on Sun May 04, 2008 11:22 am
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Re: spring relocation guide Mk1 by alex on Sun May 04, 2008 3:05 pm
I just fill the words youre all thinking. :P
Re: spring relocation guide Mk1 by Drift on Sun May 04, 2008 3:12 pm
