frontera transfer box
frontera transfer box by jellybaby on Fri May 02, 2008 12:49 pm
hi i'm new to this forum so here goes i,ve just brought a j reg frontera SWB sport 2 litre £300 not bad because someone stole my freelander, it all works well apart from the transrer box i think i,m using it right .
Stop car select gear then select transfer box option 4H, 4L or 2H then drive auto locking hubs engage when changing back to 2H reverse about three meters to dissengage locking hubs.
The only things that's not to good is the transfer box jumps out of 4H ofter a few meters 4L AND 2H are not affected.
i don't want so spend loads but if i can get all the niggiling fault mended when the freelanders repaired i might start to turn the fronter in to a weekend play toy even in two wheel drive its good off road and at a few quid not worried about paint scratches.
and where can i get spares from need two indicators.
ps is the engine the same as they used in the carlton.
thanks for your help
dave jellyman
dave.jellyman@ edit by smiffy
please dont put email addy dont want to encourage spammer put it in profile the it shows email button
Re: frontera transfer box by FUDDY MUCKER on Fri May 02, 2008 1:06 pm
This one could be a simple fix.
1. Unscrew both gear knobs
2. Unscrew to two little screws on the gear stick surround, closest to the hand brake.
3. Lift of plastic gear stick surround with the gaiters on
4. You should be able to see both gear levers easily, on the small gear stick, there should be a large spring visibily attatched, to both the 4wd gear stick and the left hand side.
Sometimes this becomes detatched, resulting in the symtoms you discribed.
Secondly, Give me a PM if your interested in two front indicators, I have both of them sitting around. £10 for the pair plus around £5 - £6 P&P
Thirdly, yes they are the same 2.0 ltr engines as the carlton, the only difference is the sump needs to be changed.
Hope this helps.
Re: frontera transfer box by Road Hog on Fri May 02, 2008 1:07 pm
Welcome,
For parts see.........viewforum.php?f=26
Or ebay or breakers yards & if all else fail VX stealers.
Re: frontera transfer box by Drift on Fri May 02, 2008 4:38 pm
Same engine as the vx cavalier.
Are you using 4wd on tarmac ?
Re: frontera transfer box by jellybaby on Fri May 02, 2008 6:08 pm
yea i tried the 4h on tarmac but in a straight line to avoid wind up is that ok.
Re: frontera transfer box by Drift on Fri May 02, 2008 6:15 pm
Just checking, its ok forr short distances.
Would be worth trying it on some loose ground and see if the same happens, also Fuddy's fix :wink:
Re: frontera transfer box by jellybaby on Fri May 02, 2008 6:24 pm
right its not the spring will try on loose ground is this starting to sound expensive
Re: frontera transfer box by jellybaby on Tue May 13, 2008 10:57 pm
changed oil in transfer box and gave everything i could see a good squirt with WD40 then tried again yippie it works shame it's such an ordeal to select 4WD the freelander was permanentish but i like having a second little knob to twiddle.
cheers every body
Re: frontera transfer box by Sir-Doris on Tue May 13, 2008 11:27 pm
The freeklander may have had permanent 4wd but the frontera has a proper hi and lo range transfer box. very handy when control is required without burning the clutch.
