Frontera Technical Support • View topic - lady in need
lady in need
lady in need by perfectprincess on Sat Apr 26, 2008 9:07 pm
hi guys
can anyone help me please ive got a problem with 1 of my fronty's
it's a 2.2 diesle with the iszu engine when i start of the engine management light comes on will not go of until i over rev the engine in 3rd gear it comes back on when i slow down or stop
any one got any suggestions
perfectprincess
Frontera Goddess
Frontera Goddess
Re: lady in need by Drift on Sat Apr 26, 2008 9:10 pm
Its not an Isuzu engine is a vauxhall engine :wink:
Could be your MAF ( Mass Air Flow ) sensor near the air box, but might be worth getting the codes read to pin point the problem if the light is staying on..
Re: lady in need by Fronty81 on Sat Apr 26, 2008 9:13 pm
Sounds like one of the Vacuum Pipes to me... probably the turbo one... check them all though just to be sure...
VX do a kit to replace the lot...
Even a small split then 1 will through the EML on...
I though the 2.2 was a VX and Fiat engine???
Although I could wrong on the Engine thing... also best to check your MAF out too, as this could be throwing a wobbly... at least that what caused mine...
Check VAC pipes first though.
Cheers.
Matt
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: lady in need by perfectprincess on Sat Apr 26, 2008 9:20 pm
hi guys
thanks for your help and advice see us woman can drive but havn't got a clue under the bonnet help is very welcome but im out in the sticks here garages few and far between out here, but may be my only joy thanks guys.
perfectprincess
Frontera Goddess
Frontera Goddess
Re: lady in need by Road Hog on Sat Apr 26, 2008 9:31 pm
where are you near ? we may be able to get a local member to pop round & have a look !
Re: lady in need by perfectprincess on Sat Apr 26, 2008 9:34 pm
out in hunstanton norfolk thanks for the ofer babe it nice thought
perfectprincess
Frontera Goddess
Frontera Goddess
Re: lady in need by Fronty81 on Sat Apr 26, 2008 9:38 pm
Ok, if you know where the Airbox is, the MAF is dead easy to find... on the top of the Airbox (a big black box behind the left headlamp, Opposite side of the engine bay to the battery.)
There is a pipe that leads from the Airbox top, to the Turbo on the Drivers side. (a large pipe that gradually gets smaller as it connects to the Turbo)
Now, on the pipe, right after the Airbox is an electrical plug. The device that the plug plugs into is the MAF. Though only a code reader will tell you if this is broken.
Now, Vacuum pipes start in the same place, they are directly behind the Airbox.
There are 3 cylindrical "things" these things (they are black with grey tops, look like Kodak Film canisters) 1 slightly higher than the other 2, are the solonoids for the Vacuum operated devices. (Turbo, 4x4 system, EGR, etc.)
There are little black pipes that run right to the devices themselves.
You need to take each of these off in turn and inspect very closely the entire length of the pipe... the one that runs to the turbo is quite long, but you have to make sure there are no cracks, or splits.
If you have splits on the part that connects to either the solonoid or the device, then 9/10 you can cut the pipes back to new rubber and re-mount them.... it helps save a few pennies... 8).
Hope this helps.
Matt.
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: lady in need by perfectprincess on Sat Apr 26, 2008 9:46 pm
matt
you sound knowledgable shame you not live by me. ide provide the beer in return for help but thanks any way all i can do is have a go :)
perfectprincess
Frontera Goddess
Frontera Goddess
Re: lady in need by Road Hog on Sat Apr 26, 2008 9:54 pm
Dont think there are any membes in your immediate area,bobbinsjob goes to sunny hunny now & again.
Re: lady in need by Fronty81 on Sat Apr 26, 2008 9:59 pm
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: lady in need by perfectprincess on Sun Apr 27, 2008 5:01 pm
matt
you such a sweet heart thankyou i used to live in the midlands (solihull) so yes i know how far it is but if you ever over this way in sunny hunny look me up just email ok :wink:
perfectprincess
Frontera Goddess
Frontera Goddess
Re: lady in need by bobbinsjob on Sun Apr 27, 2008 6:38 pm
I will be in sunny hunny in 3 weeks, I'm no expert but can have a look
Re: lady in need by perfectprincess on Sun Apr 27, 2008 6:44 pm
babe
you more than welcome ide be glad of your help even buy you a pint !!!!
perfectprincess
Frontera Goddess
Frontera Goddess
