Frontera Technical Support • View topic - 4WDH & 4WDL
4WDH & 4WDL
4WDH & 4WDL by MARKPRIOR on Fri Apr 25, 2008 12:58 pm
ok bit of a newb question but whats the difference's / uses for these
4WDH & 4WDL
thanks
MARKPRIOR
Re: 4WDH & 4WDL by Greekfronty on Fri Apr 25, 2008 2:05 pm
4WDL you use it if you want maximum power or towing abbility like a boat or snow mud sand climb the 4WDH when you just want more traction like wet road not very deep snow e.t.c
hope I help :D
Greekfronty
Modifications: New wheels Irmscher 17" on with 245/65 michelin tyres, xenon H.I.D. kit 6000K, K&N Air Filter,
Re: 4WDH & 4WDL by Fronty81 on Fri Apr 25, 2008 2:05 pm
4WDH - Basicaly is 4x4 "mode" only to be used in the slippy stuff, but the H mens you are in "high" range on the transfere box... (you go quicker in lower gears)
4WDL - Is the same, but you are in "low" range on transfere box... this is designed for off-road and steep decents/asents, and allows the throttle to be more controllable
Cheers.
Matt
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: 4WDH & 4WDL by Fronty81 on Fri Apr 25, 2008 2:07 pm
IT'S NOT A JEEP!!
Fronty81
2" Lift
Re: 4WDH & 4WDL by weave67 on Fri Apr 25, 2008 4:08 pm
only if you want to pull that boat through mud or snow... DON'T use 4x4 at all on a dry/wet road.. you'll wind up your transmission, and unless you unwind it, something will snap! .........probably your wallet :D
Re: 4WDH & 4WDL by MARKPRIOR on Fri Apr 25, 2008 4:37 pm
cheers guys , great help :D
MARKPRIOR
Re: 4WDH & 4WDL by Drift on Fri Apr 25, 2008 5:43 pm
