flushing oil
flushing oil by colin all on Mon Apr 21, 2008 10:16 pm
anybody have any views on flushing oil ?. need to change engine oil but was wondering whether it would be advantageous to use flushing oil first.. previous car a renault, manufacturer said not to use it under any circumstances.
1999 LWB 3.2 V6 petrol/LPG
colin all
Registration Year: 1999/S
Modifications: Marrelli LPG conversion from Hytek
Heavy Duty rear springs
Re: flushing oil by Drift on Mon Apr 21, 2008 10:20 pm
For an older car with little or no history, personally I wouldn't flush, simply because the deposits in the engine can actually plug holes/gaps around seals etc, but I am fastidious about changing my oil every 3k or three months, with a filter change every other oil change, so it keeps it pretty tip top.
This is just my opinion, I know some guys prefer the flush :wink:
Re: flushing oil by Road Hog on Mon Apr 21, 2008 10:21 pm
In the workshop we only used flushing oil at the first oil change,after engine rebuild.
Re: flushing oil by colin all on Mon Apr 21, 2008 10:26 pm
my frontys mileage is 80k, and seems to have been serviced regularly for about 60k, so i think i'l just change for some good quality oil, any suggestions
colin all
Re: flushing oil by nitromotor on Mon Apr 21, 2008 11:09 pm
don’t bother with flushing, it can create more problems than it solves, unless you have a specific reason to use it, Ie if you took the rocker off and found tar and varnish, which years ago on the old spec oil was possible.
Today if I saw that, id be reluctant to change the oil for fear of upsetting it lol.
But seriously if you want to treat it, change the oil, run till worm, change again, and change oil filter, then set your self an oil and filter schedule to suit your needs, I change oil every 3 month, filter every 6 months with an oil change.
Re: flushing oil by Sir-Doris on Tue Apr 22, 2008 1:33 am
I change every 5k to 7k with filter change. Keeps on purring.
Re: flushing oil by Mossey on Tue Apr 22, 2008 8:42 am
drop the old oil and change filters, fill with a cheap oil and run for 20 mins.
then drop this oil and replace with good oil.
you may be suprised how much more crap comes out.
Mossey
Re: flushing oil by kingfisher on Fri Apr 25, 2008 11:50 pm
my fronty a 94 sport , had no oil pressure , i took it to my local garage so he could have a look , he said i needed a recon engine because the oil pump had gone , etc. anyway i took it to another garage and all they did was flush the engine , replaced the oil filter and now the pressure is back up and its running like a goodun ,he said flush the engine at least once a year .to get rid of all the sludge . so from now on thats what i will be doing from now on
kingfisher
Vehicle Name: The money pit
