Frontera Technical Support • View topic - welding
welding
welding by colin all on Sun Apr 20, 2008 10:28 pm
HI, is there any problems i am liable to encounter when welding on my frontera, i am using an arc welder (mig), should i be concerned about sensitive electronics.
thanks
colin
1999 LWB 3.2 V6 petrol/LPG
colin all
Registration Year: 1999/S
Modifications: Marrelli LPG conversion from Hytek
Heavy Duty rear springs
Re: welding by ernie1 on Sun Apr 20, 2008 10:35 pm
Just make sure you disconect the alternator and battery before you start welding,you should be ok
ernie1
Modifications: Camac A/T 40 chanel CB 2" sus lift For now!
Re: welding by colin all on Sun Apr 20, 2008 10:38 pm
thanks,
was wondering about possdible damage to ECU etc
colin all
Re: welding by ernie1 on Sun Apr 20, 2008 10:40 pm
Think you should be ok.What about the gas though,only just noticed that,don't you have to remove it?
ernie1
Re: welding by paul higgi on Mon Apr 21, 2008 7:03 pm
paul higgi
3" body lift
5;38 diffs front /rear
ARB compressor
Superwinch EPI 9
Revolution transfer gears
Cb
Surco roof rack
4 x spotlamps
Rear spotlamp
Rear tubular bumper
Isuzu trooper rear axle
Isuzu trooper front axle
Safari snorkel / RHS SS25HF
Arches cut and welded
trooper transfer case housing
Hydraulic handbrake
AVM manual locking hubs
3" Flexi Arch Kit
Re: welding by alex on Mon Apr 21, 2008 7:46 pm
Never catch me welding to a live gas tank.....
Re: welding by ernie1 on Mon Apr 21, 2008 7:51 pm
Thought as much.Was told a while back you even have to remove them before the car goes in an oven when spraying :shock:
ernie1
Re: welding by weave67 on Mon Apr 21, 2008 7:52 pm
disconect battery and remove it,out of site out of mind,as they say :D
Re: welding by colin all on Mon Apr 21, 2008 10:12 pm
thanks for replies, I have got to remove gas tank anyway to carry out welding, but i must admit I never thought about it if i was welding somewhere else on car :oops:
colin all
Re: welding by nitromotor on Mon Apr 21, 2008 10:35 pm
There is quite a lot of misinformation surrounding LPG.
The systems are safer than petrol, so there is no more risk above the petrol risk.
The same principals apply, do not weld near pipes or tank.
Unless you have leaks in the system, lpg or petrol…
As for your onboard electrickery play safe disconnect battery.
Re: welding by Alfie on Tue Apr 22, 2008 10:16 pm
Also when welding make sure you have a good earth for your welder earth clamp, shiny metal is best and earth as close to where you're welding as possible :D
Vehicle Name: Dino
