Smoke test
Smoke test by Mossey on Fri Apr 18, 2008 8:55 am
Just had my 2.8 in for test and wondered if these results were any good or not, can anyone tell me?
1 1.57
2 0.59
3 0.55
4 0.45
average 0.53 1/m
Mossey
Re: Smoke test by Road Hog on Fri Apr 18, 2008 9:31 am
Any result that ends with a pass is good......... :wink: :)
Re: Smoke test by john boy on Fri Apr 18, 2008 6:39 pm
Yeah they are good the last 3 are realy low :D
Re: Smoke test by Mossey on Sat Apr 19, 2008 7:23 am
Does that mean I could get away with turning the fuel pump up some more?
I would also comment that so far I have removed the cat, blanked off the egr, restricted the wastegate and turned the pump up 1/4 turn, oh and fitted a large cone filter so I was a bit worried about the emisions test.
Mossey
Re: Smoke test by Drift on Sat Apr 19, 2008 11:25 am
So you got away with no cat :wink:
Re: Smoke test by Red Oktober on Sat Apr 19, 2008 12:19 pm
does make interesting reading ........
how did you replace the cat ...was a bolt on affair ...or ...did you weld a piece in
Re: Smoke test by Mossey on Sat Apr 19, 2008 3:27 pm
made my own pipe joined with special joint from exhaust centre.
just been back to test centre and had a chat with the tester, the limit for the 2.8 is 3.0 1/m so could get away with loads more fuel.
Dont think people behind would agree though.
Mossey
Re: Smoke test by Red Oktober on Sat Apr 19, 2008 3:29 pm
have you noticed any differences sinse removing the cat
Re: Smoke test by Mossey on Sat Apr 19, 2008 3:31 pm
little bit better at the bottom end
Mossey
