Frontera Technical Support • View topic - Axle seal or brake cylinder
Axle seal or brake cylinder by brachunky on Wed Apr 16, 2008 7:53 pm
Some of you might have read that Im struggling to get a brake drum off(still battling :roll: ) cause I thought that the brake cylinder was leaking.But....tanight I gets under the fronty and sees that it may be an axle seal :? Thinking about it,the fluid smells a bit "diffy" :D If it is the seal,i dunno what has caused it to leak.
If it is the seal(opinions wanted please!) at least I can do Farley after topping up the diff oil.
3 inch suspension lift
31 10.5 Muds
Re: Axle seal or brake cylinder by Drift on Wed Apr 16, 2008 7:57 pm
I would expect the leak from the brakes to be on the other side of the disk guard :(
Re: Axle seal or brake cylinder by Road Hog on Wed Apr 16, 2008 8:06 pm
Rub a small amount of leaking fluid between fingertips,then compare by the same method brake fluid or EP 90 whichever you have..........It`s a basic viscosity test..............As the two fluids in question are so different it should be obvious which is leaking..
Re: Axle seal or brake cylinder by Road Hog on Wed Apr 16, 2008 8:13 pm
Studying the piccys I think it is brake fluid carrying brake dust.
Re: Axle seal or brake cylinder by Drift on Wed Apr 16, 2008 8:18 pm
Are you loosing brake fluid ?
Re: Axle seal or brake cylinder by brachunky on Wed Apr 16, 2008 8:32 pm
31 10.5 Muds
Re: Axle seal or brake cylinder by Road Hog on Wed Apr 16, 2008 8:48 pm
Re: Axle seal or brake cylinder by Red Oktober on Wed Apr 16, 2008 8:52 pm
Re: Axle seal or brake cylinder by brachunky on Wed Apr 16, 2008 9:44 pm
31 10.5 Muds
Re: Axle seal or brake cylinder by weave67 on Thu Apr 17, 2008 6:32 am
mate make sure your axle breather aint blocked :wink: i had a leak on the back plate on mine if that breather is blocked it creates a load of pressure in the axle,since i extended the breather its stopped altogether :D
Re: Axle seal or brake cylinder by brachunky on Thu Apr 17, 2008 8:23 am
31 10.5 Muds
