Frontera Technical Support • View topic - help with getting a tool kit together.
help with getting a tool kit together. by Silver Ghost on Wed Apr 16, 2008 7:05 pm
Hi guys,
As some of you know, had a lot of trouble and garage expense over last year. picking my new truck up at weekend, so wanting to keep any cost down this time, should anyhting go wrong, break and the likes.
i have a good general idea around a car, but im no expert. have done a few jobs in the past on more basic cars,
so i would like to start geeting a too lset together,
so what do i need, so far i have a socket set. its a one in mils, do i need to purchae one that in in inches, lest say 1/2 inch that sort of thing. I also have a 2 tonne trolley jack. and a few spanners in mils, do i need to get a set in inches as well, as sometime when undoing nuts and bolts, the size can sometime be just out and seems to want to slip.
what else would be a good idea to purchase, lets say to change a ball joint, change break shoes and pads and do my own basic service.
sean
Silver Ghost
Registration Year: 1999/S
:D Frontys are all metric (mils) if you have a haynes manuel it gives you a list of tools to get to work on your Fronty :D :D
Sounds like a tractor But goes like a rocket - Poor mans auto parts.
The Engineer
Vehicle Name: Dragon
Modifications: suzukigrand vitara 1.9DTI
Re: help with getting a tool kit together. by dickycaz on Wed Apr 16, 2008 7:19 pm
hi mate .. socket set you have one in mm thats ok you don't need an imperial . a good set of spanners helps try to get a set that covers 10mm -24mm you will need some pliers a set of mole grips and a good set of screwdrivers helps but you will need a 4" angle grinder even if you wont use an angle grinder every one else i no on here owns one and they say you don't need any other tool lol :lol: :lol:
dickycaz
Modifications: 2.3 td lwb
Re: help with getting a tool kit together. by Trugga on Wed Apr 16, 2008 7:20 pm
The Frontera is all metric - so you'll only need mm sockets and spanners, although an adjustable spanner can be useful, so, to start with I would suggest:
Set mm ½" drive sockets
½" reversible ratchet drive
½" breaker bar
½" short extension
Set mm open/ring spanners
A ¼" drive socket set would also be useul
Long and bull nose pliers
Circlip pliers
A good set of screw drivers, both cross-head and flat (and don't use them as chisels/levers etc)
mm set of allen keys
Torx head set (T50 for the sump guard)
Oil filter wrench
Electrical cutters and crimping tool
There's probably a few more basic tools, but I can't think of them at the momeny
Re: help with getting a tool kit together. by weave67 on Wed Apr 16, 2008 7:29 pm
a good quality breaker bar,,,oh and a big "ommer"
Silver Ghost
Re: help with getting a tool kit together. by Drift on Wed Apr 16, 2008 8:09 pm
Get yourself good quality tools.
I use Halfords Professional range great quality and good price, they have a lifetime warranty.
Snap On are great but very expensive, get that if you can afford it.
A breaker bar is a must and a huge rubber mallet :wink:
Get consumables like greases, penetrating sprays and the like.
It will take time to build up but it will pay in the end.
Cheap stuff WILL fail when your car is in bits and you cant get to the shop to replace them, or 1600 on a Sunday afternoon when you need the car next day for work :wink:
Re: help with getting a tool kit together. by Drift on Wed Apr 16, 2008 8:10 pm
Re: help with getting a tool kit together. by brachunky on Wed Apr 16, 2008 8:26 pm
A £15 blow torch is very handy too,especially on tough to remove ball joints and the like!
3 inch suspension lift
31 10.5 Muds
Re: help with getting a tool kit together. by Big Dave on Wed Apr 16, 2008 8:51 pm
pretty much covered already - big hammer, breaker bar, angle grinder, blow torch, quality tools, etc.
Get some latex gloves too - evry time i lift the bonnet i get filthy, and gloves keep my hands nice and clean :lol: :lol: :lol:
Most important - get something to shout at / swear at / beat when it all goes wrong (snap bolts, seized exhaust parts, skinned knuckles, etc) :lol:
Big Dave
_____________________________________
Fronty 94 SWB Sport 2.0i - Broke it
Little Blue Van 96 SWB Sport S 2.8TDi - Sold it
Member of http://www.northtyne4x4.com http://www.4x4uk.org
Big Dave
Vehicle Name: Honda Civic
Modifications: Dreams
Re: help with getting a tool kit together. by Road Hog on Wed Apr 16, 2008 9:04 pm
You will need both male & female Torx Bits............If you can find one a 36mm box spanner for the oil filter canister.also this will pay for itself http://cgi.ebay.co.uk/VAUXHALL-OPEL-FRO ... dZViewItem
Silver Ghost
Work safely, jack with axle stands, watch out for the spanner slipping off and loosing knuckles ect.
Wear sensible clothing, ie not getting caught in moving parts Boots incase dropping bits on your foot!
get a set of impact/6 sided sockets so they don't slip off. Especially when using the breaker bar.
Any other "specialist" tools buy as you go along. It will still save your money compared to garage costs.
You get what you pay for, so keep with good brands. I use a Draper Budget socket set, and not broke it yet.
jim in the city
Model: 2.2i San Diego 5dr
Modifications: furry dice
Re: help with getting a tool kit together. by nitromotor on Thu Apr 17, 2008 10:11 pm
Buy a good 3/8th drive socket set, such as snapon, facom or teng.
You don’t need a big set to start off with as you can slowly build it up over time.
A quality 3/8th set is stronger, lighter, better fitting, and of more benefit than a cheap ½ inch set.
The main tools are a good hammer, then a bigger hammer.
If you are doing your own servicing then buy a oil drain tray, grease gun, torque wrench, G cramps,
Verna gauges, micrometer and a tyre depth gauge in addition to the usual hand tools.
You can also make your own tools, to start with try a brake adjust tool for the rear shoes
Re: help with getting a tool kit together. by Drift on Thu Apr 17, 2008 10:20 pm
You only really need a hammer.... coz if that cant fix it then its and electrical fault :D
Re: help with getting a tool kit together. by alex on Fri Apr 18, 2008 4:07 pm
torsion bar bolt is 27mm, a good socket for that if you want to lift/adjust ride height.
I second the comments on good tools, I used to have loads of sets of cheap ring spanners andthe like an had more rounded nuts and bolts than not. Jobs just seem easier with the right tools.
Halfauds have a nice 4tonne bottle jack, fits in the cubby hole the original vx comes in, lifts my cars perfectly. Dont forget some sort of bought/home made wheel chocks to stop it rolling off as you jack.
Silver Ghost
Re: help with getting a tool kit together. by Trugga on Fri Apr 18, 2008 7:19 pm
