flashing glow plug light
flashing glow plug light by Rikfrontera on Tue Apr 08, 2008 1:36 pm
After breaking a fuel pipe connector..repairing it,bleeding the fuel and finally starting it again I get a flashing glow plug light for up to a min before it goes out.
This morning it was really hard to start, eventually she did and probably will the rest of the day but I bet in the morning its the same problem..thats if she even starts at all.
NEW GLOW PLUGS? or some other fault caused by the fuel pipe breakage?
I did still start the engine and ran it to the breakers with the broken fuel line plugged :oops: do you think this damaged or cooked the glowplug? :cry:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Registration Year: 1994/M
Modifications: New AMAZON MUD TERRAIN TYRES, 30mm Wheelspacers and raised the numberplate... would like a lift kit and snorkel
Re: flashing glow plug light by dickycaz on Tue Apr 08, 2008 3:48 pm
i had the same problem with mine a few month ago . i cleaned up all the terminals but it never helped so i checked my glow plugs and two were f##### so i changed them all and the light went out and starts every time . i still have the address on e bay if you require it :twisted: :twisted:
dickycaz
Modifications: 2.3 td lwb
Re: flashing glow plug light by Rikfrontera on Tue Apr 08, 2008 7:48 pm
Thanks mate, :) that would be great, I found one set on ebay quickly but would be happy to check your seller out as proven good. :D
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: flashing glow plug light by dickycaz on Wed Apr 09, 2008 5:35 pm
pm sent mate . :twisted: :twisted:
dickycaz
Re: flashing glow plug light by Rikfrontera on Wed Apr 09, 2008 6:07 pm
Thanks, checkin it out now. :) :twisted:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: flashing glow plug light by Rikfrontera on Wed Apr 09, 2008 6:14 pm
BOUGHT AND PAID FOR. THEIR THE ONLY ONES ID FOUND TOO. LOOK FORWARD TO RECEIVING THEM AND GETTIN FITTED :)
THANKS MATE :D
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: flashing glow plug light by dickycaz on Wed Apr 09, 2008 6:16 pm
any time mate :twisted: :twisted:
dickycaz
Re: flashing glow plug light by Rikfrontera on Thu Apr 10, 2008 2:35 am
Hi mate Just had a nasty thought... yes at 2.30am.... While previously repairing a broken fuel pipe connector that I heavy handedly broke :oops:
I also decided to unplug an then fasten the fuel filter heating element temperature switch :oops: Looking in the haynes it sez to disconnect the neg terminal on the battery before doing so...Which I hadn't. :oops: The worst thing is I had no need to undo the switch in the first place.. :!:
Could this be the cause of the faulty struggled start and also flashing glowplug light once started :?:
Im wondering if i've done a fuse or relay..... instead of actually killing one of the glowplugs itself. :oops:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
