Please can someone help me
Please can someone help me by Rikfrontera on Sun Apr 06, 2008 5:11 am
frontera 2.3 fuel pipe connector.
Ive only gone and snapped the fuel pipe connector to the first cylinder... :oh yer: Ive tried to get one from the local scrapers with no luck, Its the small plastic pipe joining the fuel hoses. Two ends and on one side two smaller connections that go to either side of the glow plug..
IF ANYONE CAN PUT THEIR HAND ON ONE ID LOVE TO HAND OVER SOME GOOD ENGLISH POUNDS FOR IT AND THE POSTAGE. :)
the only problem like normal is needing the part yesterday and never being able to source it that quick. :cry: O well walking will do me good...the mrs sez! :evil:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Registration Year: 1994/M
Modifications: New AMAZON MUD TERRAIN TYRES, 30mm Wheelspacers and raised the numberplate... would like a lift kit and snorkel
Re: Please can someone help me by LINE-X Cornwall on Sun Apr 06, 2008 8:40 am
If this happend to me in the field i would probably do as you have done so far
Then ......
Cut the black rubber pipe 1.5" from where it joins the larger pipe
Rob the windscreen washer pipe T piece (located under the bonnet near the windscreen)
Fit to the cut ends of the rubber pipe & attach remaining diesel return pipe.
This would get you going as a "get you home fix"
For a more pernament fix rob the required T piece from another vehicle :D
1995 2.8 lwb
1995 2.0 swb
1992 2.3 lwb,,,,, is it red or is it green ? its my old new play machine !!!
1997 2.2 lwb ,Decided to break this one, Very excelent 120k petrol engine !!! serious offers invited.
1995 2.4 lwb A FEW PARTS LEFT FOR SALE !!!
LINE-X Cornwall
Modifications: 2"lift
Re: Please can someone help me by john (smifffy) on Sun Apr 06, 2008 8:47 am
have you tried a diesel service center they might have something in the stock
if your really stuck you could try a pet shop for the connectors they use on fishtank airpipes just use a couple of T pieces
Re: Please can someone help me by Drift on Sun Apr 06, 2008 10:37 am
Any motor factors should sell hte T joints it a very common peice, up until recently I had one in my tool box from a mark one orion 16i ghia :lol: would be a bit small for yours though.
Re: Please can someone help me by bobbinsjob on Sun Apr 06, 2008 11:01 am
Failing that, small bore garden irrigation systems use the same things, couple of quid at homebase
Re: Please can someone help me by Rikfrontera on Sun Apr 06, 2008 1:25 pm
:) :) Thanks for all the advice guys ill get stuck into that,.... Hopefully will be running again very soon :D :drive:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: Please can someone help me by Rikfrontera on Sun Apr 06, 2008 5:07 pm
Well ive done the repair after walkin in the snow to the garden centre, Can see fuel getting into the pipes again :) but engine wont start... Does anyone know any problems that could have risen from not having those pipes connected while engine was still running.(general fuel starvation..? damaged heater plug...? Air in the fuel lines..?etc etc) Thanks
Oh and the repair bits only cost 50p :dance:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: Please can someone help me by Drift on Sun Apr 06, 2008 5:12 pm
Air in the fuel, it will need priming :D
Re: Please can someone help me by Rikfrontera on Sun Apr 06, 2008 5:14 pm
Basically.. when the breakage happened I put the screws in to seal the leak then because the truck still started I ran it to the breakers and back :oops: but the following day it wouldnt start..... Now ive done this repair it still wont start. :dunno:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: Please can someone help me by Rikfrontera on Sun Apr 06, 2008 5:15 pm
Right, thanks Drift. :D
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: Please can someone help me by Rikfrontera on Sun Apr 06, 2008 7:57 pm
Ive primed the fuel...but still nothing, :cry: Think I need to bleed it all :!:
Oh well.. its the first motor ive actually got dirty messing about with so its all good stuff.
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Re: Please can someone help me by rangaKoo on Sun Apr 06, 2008 10:24 pm
Just crack off the injectors and pump for a little while on the hand pump... as long as the fuel hasn't managed to drain back in to the tank it should come out of the injectors fairly easily.. And if it's not then crack off the bleed nipple on the side of the pump.
rangaKoo
Re: Please can someone help me by Rikfrontera on Sun Apr 06, 2008 11:37 pm
Thanks
Will give it a go in the morning.. Cant wait to hear it fire up again. There was fuel pumping out the bleed screw on the side of the pump earlier and also from the screw in the centre of the injectors, just need to do it all in the right order... the haynes sez to turn on the ignition to activate the stop solenoid also.
I will have it running tomorrow........ :drive:
[url]Image
[/url]
MA LIL MULE
Rikfrontera
Users browsing this forum: Google [Bot] and 40 guests
