Frontera Technical Support • View topic - Am I being a wuzz?
Am I being a wuzz?
Am I being a wuzz? by Paul A on Mon Mar 24, 2008 2:56 pm
Hi,
Wifey bought me chainsaw for Christmas 16" bar 2 stroke 50cc jobby - so quite powerful.
Finally got round to assembling it today (Put bar and chain on).
I want to use it today to cut some logs as we've finally run out.
Thing is..... it scares the bejeesus out of me! :shock: :shock: :shock:
Any one got any tips?
I've read the manual about ten million times and looked at loads of pretty scary stuff on the web.
Am I just being wuzzy? :?
V6 Isuzu Vehicross
Paul A
Re: Am I being a wuzz? by Silver Ghost on Mon Mar 24, 2008 3:10 pm
No your not being a wuzz as you say,
Im a timed served would machinest, and seen lots of silly accidents, the od finger lost, and even a peice of 22foot 2*1 go straight through a guy. and i also was very lucky that i had a rip saw blade only showning 5mm, which to my cost, shattered 2 fingers and 18 stitches, what if the balde was higher, ( loss of fingers i guess).
follow all instrctions, always cut away from yourself, Most of all dont cut any corrners, and wear all saftey gear, gloves, glasses, or face sheild would be even better.
if you follow all safety procedures, the saw will do the rest. and will be your friend.
the biggest advice i can give, is RESPECT IT FOR WHAT IT IS. a machine for cutting.
sean
Silver Ghost
Registration Year: 1999/S
Re: Am I being a wuzz? by Red Oktober on Mon Mar 24, 2008 3:12 pm
i'd say no....
it's very easy to look on the web and scare yourself stupid about what might happen if your stupid with it.....
you just need to practice some self discipline and try it out on something small first ......
Re: Am I being a wuzz? by Silver Ghost on Mon Mar 24, 2008 3:15 pm
Silver Ghost
Re: Am I being a wuzz? by Drift on Mon Mar 24, 2008 4:10 pm
Re: Am I being a wuzz? by dandan on Mon Mar 24, 2008 4:32 pm
I'm a certified chainsaw operator (which reminds me I must do the update course soon) and have seen a couple of near misses in my time.
here was a tree surgeon killed last week round this way as well after being caught out by a "kick-back" (Article).
Please don't take any offence by this but it still amazes me that any Tom, Dick or Harry can go out and buy such a dangerous piece of kit without any sort of formal training and yet to hire one or operate one in a public place you have to be licensed! :soap box:
Give the machine the respect it is due!
If you're sat there thinking things just can't get any worse, just wait......
dandan
Re: Am I being a wuzz? by dickycaz on Mon Mar 24, 2008 4:33 pm
if your that scared of it then stick it on ebay and keep all your fingers. :twisted: :twisted:
dickycaz
Modifications: 2.3 td lwb
Re: Am I being a wuzz? by dandan on Mon Mar 24, 2008 4:55 pm
You can't be scared of it or it'll bite you in the arse.
Couple of tips when cross cutting (some of which are very similar to using a petrol disc cutter)
NEVER use the tip of the saw. You're just asking for trouble.
NEVER lean over the saw.
ALWAYS wear safety equipment. As a minimum you should wear ear defenders, goggles, gloves and safety footwear.
ALWAYS apply the chain brake when the saw is not cutting. If it's not in use turn it off IMMEDIATELY.
ALWAYS use common sense. Sounds daft but hey.
TRY to make sure the cut will "open" so that the saw does get "pinched" as this is another cause of kick back.
The straighter your arms the more likely something will go wrong. It's not to everyones liking but I always have the "tail" of the saw as close to my hip as possible.
If in doubt.....STOP!!!
dandan
Re: Am I being a wuzz? by Drift on Mon Mar 24, 2008 4:57 pm
:shock: sod that :shock:
Buy an Axe :D
Re: Am I being a wuzz? by Red Oktober on Mon Mar 24, 2008 5:08 pm
Re: Am I being a wuzz? by dandan on Mon Mar 24, 2008 5:38 pm
This is my little baby Image
dandan
Re: Am I being a wuzz? by Drift on Mon Mar 24, 2008 5:41 pm
I still think and axe is safer :shock: :axe:
Re: Am I being a wuzz? by Tiddles on Mon Mar 24, 2008 5:46 pm
I used to use them for a living and they can be a bit scary at first :)
Just treat it with respect and make sure you ALWAYS were the protective trousers, boots and helmet :idea:
I had on bite me in the leg but thankfully the trousers stooped it gong through :!:
Never ever start it off the ground and apply the chain brake every time you stop cutting. Make sure that people know to ONLY approach you from your right side. As when you let go of the back handle the saw will swing to your left side :D
Tiddles
Modifications: 2" lift
Nice gripy tyres :)
Re: Am I being a wuzz? by woodwizzard on Mon Mar 24, 2008 6:10 pm
I produce logs as part of my living and one of the best £100 I spent was on a metal saw horse that you clamp your chainsaw to. It has a guard that goes over the bar and you can operate it one handed and feed the log in with the other hand. You don't have to keep picking up and putting down the saw and it saves your back as well as time. They have them in machine mart or screw fix I think and they are made by pro-logic. Mine has lasted 4 years of pro use and is now looking a bit tatty so it should last a home user years. It makes cutting logs safe and very efficient.
Re: Am I being a wuzz? by Rich2.4i on Mon Mar 24, 2008 7:08 pm
I Like this Truck of mine, just like me it's well run in it's not old just older.
My Truck's :
Playtoy : '94 M Frontera 2.4i LWB NOW SOLD AS DIED
Family truck : '07 Ford Ranger Thunder 2.5 TDCI
Rich2.4i
Location: Hereford, (Which i have Now moved to south wales)
Registration Year: 1994/M
Vehicle Name: MUDDY DUCK
Modifications: MY PLAY TRUCK ( MUDDY DUCK ) : 2.4I LWB FRONTERA '94 M
New look grill,
CB fitted,
Bull bars,
Side steps,
Removed All mud flaps,
16" Chevy Blazer Alloy wheels,
Removed spare wheel carrier from the rear,
front valance trimmed a Little,
Snorkel ( NOT HOME MADE )
Rearranged back bumper & quarter panel
NOW SOLD AS DIED ....................
MY Car :
Ford Ranger Thunder '07
Skype Username: Fallen1
Re: Am I being a wuzz? by ernie1 on Mon Mar 24, 2008 7:26 pm
I used to work for a Plant hire firm,I was always amazed when so called trained operators used to ask us to put the bar and blade on for them
Unbelievable that you can't buy a good hunting knife in this country,but you can buy a chain saw
If you aint sure about it then dont use it :axe:
ernie1
Modifications: Camac A/T 40 chanel CB 2" sus lift For now!
Re: Am I being a wuzz? by Drift on Mon Mar 24, 2008 7:30 pm
Re: Am I being a wuzz? by dandan on Mon Mar 24, 2008 7:33 pm
They even have to ID you (if you look around 18, but I don't s'pose thats a problem many of us have) if you are buying a screwdriver!!! :shock: :shock: :shock:
dandan
Re: Am I being a wuzz? by woodwizzard on Mon Mar 24, 2008 8:01 pm
Re: Am I being a wuzz? by dandan on Mon Mar 24, 2008 8:10 pm
Have a read of THIS
dandan
