That "paperclip" trick...
That "paperclip" trick... by Wilberforce on Sun Mar 16, 2008 9:57 pm
I'll lead with a grovelling apology, but I have a non-Fronty (albeit Vx) question to ask... :oops: :oops:
My flatmate's got a V-plate 1.0 Corsa which has refused to start today, and is playing disco with the Engine Management light. Anyone know if it possible to pull the paperclip trick on these things, and if so where's the diagnostic plug?? If I remember correctly from doing it on my previous 2.2 engine, it was behind the O/S headlamp, and you had to short pins 1 and 2??
Re: That "paperclip" trick... by Red Oktober on Sun Mar 16, 2008 10:02 pm
don't think it works on a newer vx engine .....
Re: That "paperclip" trick... by dandan on Sun Mar 16, 2008 10:13 pm
Been posted before but......clicky
HTH
EDIT: Might not......
If you're sat there thinking things just can't get any worse, just wait......
dandan
Re: That "paperclip" trick... by Mrs Rich2.4i on Sun Mar 16, 2008 10:20 pm
As Carl said I don't think that it will work on newer engine
one of these could be the problem
Common problems are: 1. Air Flow Meter 2. Temp Sensor, 3. EGR Valve (Exhaust Gas Recirculation), 4. Idle Air Control Valve.
Idle air contol valve is the most likley suspect so probably check that first
Mrs Rich2.4i
Re: That "paperclip" trick... by Wilberforce on Sun Mar 16, 2008 10:22 pm
Well, thanks for the replies guys... I'll have a squizz under the bonnet in daylight tomorrow, and see if I can see anything...
If not, well, at least i'm 100% that I can tow the offending car to the mechanics, hehe :lol:
Re: That "paperclip" trick... by Andyf on Mon Mar 17, 2008 10:14 am
if the EML is flashing that means the immobiliser has kicked in has he dropped the key ? check to make sure the little black chip is in the key if not try spare key you can buy the chip seperate from a dealer and get key coded
Andyf
Vehicle Name: Green Machine
Modifications: set of insa turbo mud tyres, 2 inch lift, cb,
Users browsing this forum: Google [Bot] and 41 guests
