Frontera Technical Support • View topic - Quick Help needed
Quick Help needed
Quick Help needed by stevelee24 on Tue Mar 11, 2008 2:18 pm
Hi
Ive got asmall leak in my rad at the bottom, i need to get to the airport and back tonight about a 10 mile round trip and just want to patch the leak until thursday when i get the new rad.
I have some p38 body filler do you think it would be ok to slap some on over the bottom plastic part to to stop the leak for now. I was worried that the rad temp might set it on fire when hard or something as i dont know much about rads
Any help much appreciated
stevelee24
Re: Quick Help needed by Red Oktober on Tue Mar 11, 2008 2:22 pm
don't think it will hold ..due to the water and tempreture
how big is the leak .....have you got any "radweld"
Re: Quick Help needed by stevelee24 on Tue Mar 11, 2008 2:35 pm
the leak is not that bad its not exactly gushing out, i have a new tub of rad weld in the garage but i heard it can cause problems like blown head gaskets and stuff so wasnt sure about using it
stevelee24
Re: Quick Help needed by Red Oktober on Tue Mar 11, 2008 2:39 pm
you're gonna have to replace your rad asap anyway ......
what fronty you got ..so we can start looking for a replacment rad
Re: Quick Help needed by stevelee24 on Tue Mar 11, 2008 2:47 pm
ive got a 94 fronty sport, theres a rad going on ebay almost new im watching but i need a quick fix for today as im picking wor lass up at the airport tonight.
ive got a small tub of rad weld do you think putting abit in would be ok, i mean i dont want to break my engine altogether for the sake of a rad
ive got some black car silicone the type for fitting body kits aswell i was wondering if abit of that might do
its just a drippy leak
stevelee24
Re: Quick Help needed by Red Oktober on Tue Mar 11, 2008 2:50 pm
does the silicone stuf ..stand up to a fair heat ??
Re: Quick Help needed by stevelee24 on Tue Mar 11, 2008 2:53 pm
hmm says 25oc on the tube
dont know how hot a rad gets but i think its probably more than that but with the leak being on the bottom join between the metal and plastic might not be as hot
stevelee24
Re: Quick Help needed by stevelee24 on Tue Mar 11, 2008 3:18 pm
well ive used the p38, just hope it holds ok without burning up :roll:
stevelee24
Re: Quick Help needed by Red Oktober on Tue Mar 11, 2008 3:21 pm
ok ....keep an eye on it ..and let us know how it goes ... :wink:
Re: Quick Help needed by stevelee24 on Tue Mar 11, 2008 3:25 pm
stevelee24
Re: Quick Help needed by The Engineer on Tue Mar 11, 2008 3:35 pm
:D Should be ok the botom is the coolist part of the rad :D
Sounds like a tractor But goes like a rocket - Poor mans auto parts.
The Engineer
Vehicle Name: Dragon
Modifications: suzukigrand vitara 1.9DTI
Re: Quick Help needed by Drift on Tue Mar 11, 2008 4:11 pm
As a temp fix use metal putty, any factors even halfords sell it.
Re: Quick Help needed by stevelee24 on Tue Mar 11, 2008 5:04 pm
well fitted the rad back in il let you know how the p38 holds up
stevelee24
Users browsing this forum: Google [Bot] and 40 guests
