Frontera Technical Support • View topic - frontera b clutch slipping slightly
frontera b clutch slipping slightly by timsey on Sun Mar 09, 2008 7:06 pm
Hello
My 2.2dti 2000 frontera clutch has started to slip slightly, could anyone give me any advice on the same,Eg does it require adjustment,or replacing.If it is adjustment has anyone got any advice on were the adjuster is.
Any advice will be warmly welcomed.
Thanks
paul
Things to do, places to go
timsey
Re: frontera b clutch slipping slightly by Drift on Sun Mar 09, 2008 7:33 pm
If its slipping it will need replacing unfortunately.
Re: frontera b clutch slipping slightly by timsey on Sun Mar 09, 2008 7:45 pm
Thanks for your reply DRIFT, just thought there may have been some adjustment.
Thanks
again
timsey
Re: frontera b clutch slipping slightly by Red Oktober on Sun Mar 09, 2008 7:48 pm
nope .....it will need replacing
Re: frontera b clutch slipping slightly by timsey on Sun Mar 09, 2008 7:53 pm
Cheers red oktober, any idea,s of price for parts and labour.
Thanks
Paul
timsey
Re: frontera b clutch slipping slightly by Red Oktober on Sun Mar 09, 2008 8:00 pm
i just had mine done on my 2.8 A series at a cost of £320 ..
Re: frontera b clutch slipping slightly by timsey on Sun Mar 09, 2008 8:03 pm
cheers Red Oktober was that a dealer or local garage.
timsey
Re: frontera b clutch slipping slightly by Paul A on Sun Mar 09, 2008 8:04 pm
Hi,
Just had mine done,
Clutch £146, labour £250 (cash).
Not too bad in the scheme of things ....
V6 Isuzu Vehicross
Paul A
Re: frontera b clutch slipping slightly by timsey on Sun Mar 09, 2008 8:09 pm
Cheers Paul A i will have to ring around Monday, Just for reference what sort of mileage did you have on the clock when it required changing.
timsey
Re: frontera b clutch slipping slightly by Red Oktober on Sun Mar 09, 2008 8:49 pm
Re: frontera b clutch slipping slightly by Paul A on Sun Mar 09, 2008 10:19 pm
Hi,
I only had 50,000 on the clock.
There is a problem with the b series clutches in as much as if you slip the clutch a lot (as in town/city driving) they get very hot and the springs in the plate go weak.
Exactly what happened to mine.
There was loads of life left on the lining but the springs were so weak they almost fell out! :shock:
Make sure you get a good make of clutch, the one I got was "Quinton Hazell".
V6 Isuzu Vehicross
Paul A
Re: frontera b clutch slipping slightly by Red Oktober on Sun Mar 09, 2008 10:41 pm
mine was a "valeo" kit :D
Re: frontera b clutch slipping slightly by timsey on Mon Mar 10, 2008 6:26 am
timsey
Re: frontera b clutch slipping slightly by stuartdean on Fri Feb 27, 2015 3:55 pm
Sorry to jump on the band wagon. My clutch is making some strange noise when the peddle is pressed down almost like a grinding noise it dont do it every day though any ideas guys ? Could it be the plate im wondering. Mine is a frontera b 3.2 v6 limited
stuartdean
Vehicle Name: Reo
Modifications: Sports exhaust and sound system
Re: frontera b clutch slipping slightly by 4x4 bobby on Fri Feb 27, 2015 10:01 pm
Posible the dmf starting to play up but someone with better knowledge will be along shortly.
Re: frontera b clutch slipping slightly by stuartdean on Sat Feb 28, 2015 2:11 pm
Cheers bobby im totally useless at this sort of thing lol
stuartdean
Vehicle Name: Reo
Re: frontera b clutch slipping slightly by AskDean on Sat Feb 28, 2015 3:26 pm
Could be thrust release bearing from middle of clutch plate. If you have to change that check clutch while there is it needs changing do it.
AskDean
Skype Username: askdean
Re: frontera b clutch slipping slightly by AskDean on Sat Feb 28, 2015 3:27 pm
AskDean
Re: frontera b clutch slipping slightly by stuartdean on Sat Feb 28, 2015 10:00 pm
Cheers dean
stuartdean
Vehicle Name: Reo
Re: frontera b clutch slipping slightly by stuartdean on Thu Mar 19, 2015 12:41 am
Clutch all sorted. It was the bearing
stuartdean
Vehicle Name: Reo
