new project `
new project ` by muddypluka on Wed Mar 05, 2008 12:59 am
ok so now i have a coil sprung version of the swb
obvious mods
tyre
suspension lift ect
few questions?????????????
1st
dislocation cones ( dont tell me they cnt be done )
when fitting them what can i use to give downforce on the rear diff on full articulaion and dislocation
as in when 1 wheel droops out of its spring seat because fronties dont have locking diffs this will cause me a problem through making the lighter wheel spin loosing traction,
2nd
i recon i can loose about ten inches off the back of the truck to create aa greater decent angle and about ten inches off the front to give a greater attack angle ( didnt no the right term) if i remove the anti roll bar what will it do
3rd
whats megasquirt ????????????????????
what do i need to create this system ?????????
how does it work ?????????????
muddypluka
Modifications: first fronty dead and burried ( i broke it )
second fronty
machos 31/10.5/15
lights done
things to be done asap
bobtailed face lifted doubled bash plates
suspension lift
possible dislocation cones on rear not decided yet
internal fuel tank roll cage
recovery points
harnesses
Re: new project ` by Drift on Wed Mar 05, 2008 12:46 pm
Ten inches off the rear might be more work than its worth ?
Where would the fuel tank go? or are you stripping it out as a toy ?
Just moving the fuel tank inside and remove the bumper, towbar ect will increase departure angle.
You wont get anything like that of the front wothout some major surgery, will need the radiator moving somewhere ??? and steeering ??
If Ive read he dislocating cone bit right, there aint much you can do to stop a non lsd slipping, but I use heavy duty tie wraps to keep the coils in place, no problems yet, but my anti roll bar limits travel, the removel of the anti roll bar will give more travel to the axle along with other mods there is a thread in suspension section about that somewhere.
Mega squirte I aint a clue lol.
Re: new project ` by Road Hog on Wed Mar 05, 2008 12:57 pm
Removal of the anti-roll bar will be an MOT failure.
Megasquirt see here http://www.megasquirt.info/ good luck !!
Re: new project ` by muddypluka on Wed Mar 05, 2008 1:31 pm
much apriciated peeps
this wont be road going its a toy just to clarify like me old 1
drift i want the coils to dislocate to give emense travel i will be fitting storps to stop the diff from reaching damper breakaway but is there anything i can add to give extra downforce maybe a small coil on the either side of the diff casing in the centre of the truck the fuel tank is being put behind the seats as well as the batterey and rad putting some weight over the centre of the truck might even add some balast too ill try to save a immage after some editing to show what im thinking ?????
thanks for the info on mega squirt looks interesting
yes im moving the rad from the front and the pipes for the steering but the steering box will be left in place
there are some parts of this project that are going to be very scary to do but i have the urge to give it a try lol
muddypluka
second fronty
machos 31/10.5/15
lights done
suspension lift
recovery points
harnesses
Re: new project ` by alex on Wed Mar 05, 2008 1:42 pm
The shockers will limit any drop, so its not beyond scope looking for a spring over shocker that has same extension as the shocker at max extension. then mod to mount in existing shocker mounts. failing that some sort of spring inside, but cant see them giving much downforce.
Re: new project ` by Drift on Wed Mar 05, 2008 1:58 pm
Good on ya for a beastie.
The extra springs/coils further along the axle would counter act each other so no benefit gained. open longer coils would help (cant remember techi name) Suzuki's use them for mega articulation with huge shocks, but that brings other issues with prop angles and mountings.
One £££££££ option is portal axles front and rear with coil overs on, heavy ,tough and massive, but sadly very expensive.
It might be better getting the weight central on the car, ballast would lower your suspension ride and could lessen articulation.
Or you could go the route Higgi has gone with trooper axles, take a look at planet Isuzu site, that will fill you with ideas .
Re: new project ` by shez on Wed Mar 05, 2008 10:54 pm
if you remove the antiroll bars competely it is not an mot failure! if its there, and its at fault then its a fail! if its not there, what can it fail on? theres nothing to fail it on..
have asked the question many times in work due to my own cars failing in the past in silly stuff!
shez
Re: new project ` by muddypluka on Wed Mar 05, 2008 11:37 pm
from what i can remember if it fails the mot it will be because the bushes have worn or it has snapped these are the only two reasons i can think of
muddypluka
second fronty
machos 31/10.5/15
lights done
suspension lift
recovery points
harnesses
Re: new project ` by Drift on Wed Mar 05, 2008 11:53 pm
Check this thread out on mudclub for some mental ideas
http://www.mud-club.com/forum/index.php ... 4.810.html
Re: new project ` by muddypluka on Thu Mar 06, 2008 12:12 am
i can chack without registerin lol ill register then check
ill let you no if i use any of the ideas
muddypluka
second fronty
machos 31/10.5/15
lights done
suspension lift
recovery points
harnesses
Re: new project ` by Drift on Thu Mar 06, 2008 12:14 am
Its mainly pics of other 4x4's flexing, you can pic up a few ideas even pm the owners :wink:
Re: new project ` by Red Oktober on Thu Mar 06, 2008 12:20 am
i would've thought there were some "extreme" suspension setups on difflock.com
Re: new project ` by muddypluka on Thu Mar 06, 2008 12:23 am
well ill go to thr foot of our stairs
pull down my pants and spank me :butt:
im in love with the orange suzi
how in the omg hmmm think i should have ignored that site lol now i have a goal to reach lol
( :? scratches head and thinks :? )
muddypluka
second fronty
machos 31/10.5/15
lights done
suspension lift
recovery points
harnesses
Re: new project ` by Drift on Thu Mar 06, 2008 12:31 am
Whoops.... a monster is born :lol: :lol: :lol: :lol:
Re: new project ` by muddypluka on Thu Mar 06, 2008 12:38 am
i hope so lol thats the intention
if i can get the back to articulate that much what is the cenario with the front it should just sort of balance our when the front twists the body will twist with it when the back twists the front will just site there am i right ?????????
muddypluka
second fronty
machos 31/10.5/15
lights done
suspension lift
recovery points
harnesses
Re: new project ` by Red Oktober on Thu Mar 06, 2008 12:42 am
to be honest chris ...if you want to acheive that kind of articulation you'll be looking at fitting a live axle on the front ....just not sure if it's possible to mod the chassis to accept a coil sprung axle on the front
Re: new project ` by Drift on Thu Mar 06, 2008 12:46 am
Sadly no :cry: with independant front suspension the front will just hang .
If you look at this pic you will see my front wheel is just slightly off the ground, since Ive got bigger tyres and a few minor tweaks, it will never be as good as a live axle, but Im happy with the set up Im on with a few more minor adjustments, as the car is mainly for laninmg and road work.
[img]http://i105.photobucket.com/albums/m237/Driftwood28/laning%20Wales%2016%20may%[/img]
Re: new project ` by muddypluka on Thu Mar 06, 2008 12:49 am
live axles have been looked at but hmmm
ive even looked at using a frontie rear axle on the frotie front lol
this is still on the drawing board to be assessd when the front is chopped to give better aproach angle
oooooooo
forgot to say i can loose 15 inches off the back lol shes really gonna be short lol
and thats keeping the rear diff mounts as standard i did a little sketch type of thingy with paint just to see what she may look like
beware this isnt for the purists lol
muddypluka
second fronty
machos 31/10.5/15
lights done
suspension lift
recovery points
harnesses
Re: new project ` by Drift on Thu Mar 06, 2008 12:54 am
Eekk :shock: .. and thats just at the big horn wheel :lol: :lol:
You cant use the rear live on the front as it would pull in the wrong direction, would be fun to watch though 8) :lol: :lol:
In reality there would be an almighty grind and bang as a diff collasped as it went the wrong way.
TBH it wouldnt be worth bobbing a sport, just clear the clutter under it would gain the same difference :wink:
Re: new project ` by muddypluka on Thu Mar 06, 2008 12:58 am
its not just the clutter i want it to look different to any other out there
u could say im a bit on the mentalist side lol this may just turn out to be a big pile of scrap metal lol
but im in serious stages of shal i sharnt i lol
i have some hairbrain ideas sometimes some work some dont but i normally manage to do something weird lol
muddypluka
second fronty
machos 31/10.5/15
lights done
suspension lift
recovery points
harnesses
